Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Should I grind and finish these welds or leave them be???
Old 02-07-2015, 08:14 PM
clintonvillian clintonvillian is offline
clintonvillian has a good reputation on FTE.clintonvillian has a good reputation on FTE.
Click the image to open in full size.
__________________
1956 F100
Old 02-07-2015, 08:15 PM
Ok so I am pretty much finished welding these. I can grind them down, but I also don't think the welds look bad. They will look even better after blasting removes the final boogers..........
What do you think? Grind and finish? or leave them?
Keep in mind that no filler can be applied do the temps, and powder coating process.
__________________
1956 F100
Old 02-07-2015, 08:20 PM
Skalywag Skalywag is offline
Skalywag is starting off with a positive reputation.
As they say around where I live....them is to purdy to cover up.
They also say that about certain female body parts too.
__________________
1950 Ford F1/ Jezebel
(The Other Woman)
Old 02-07-2015, 08:23 PM
bigwin56f100's Avatar
bigwin56f100 bigwin56f100 is online now
bigwin56f100 is a splendid one to beholdbigwin56f100 is a splendid one to beholdbigwin56f100 is a splendid one to beholdbigwin56f100 is a splendid one to beholdbigwin56f100 is a splendid one to beholdbigwin56f100 is a splendid one to beholdbigwin56f100 is a splendid one to beholdbigwin56f100 is a splendid one to behold
Thats so cool! I wish I could do stuff like that. I say leave it. Too bad it was made on the wrong side of the RIVER! Just kidding
__________________
"Some trucks must die for other trucks to live"......... Kevin
Old 02-07-2015, 08:26 PM
Wrong side of the river? I don't get it? lol
__________________
1956 F100
Old 02-07-2015, 08:27 PM
Ohia river
__________________
Old 02-07-2015, 08:33 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to behold
OK, what is the application? Looks like it will work well as is. Shows lot of work. How many hours involved?
__________________
Ray
1949 F-4 Built to drive--script bed.
1956 F350 Stock rebuilt script bed
2007 F150 SC. Driven once in a while. 2015 Escape SE EB 1.6 Wife's ride
Government conceived by genius, now operated by fools.
Old 02-07-2015, 08:43 PM
probabally 50+ hours and it is for a 300 six
__________________
1956 F100
Old 02-07-2015, 08:58 PM
fabieber fabieber is offline
fabieber is starting off with a positive reputation.
If I could weld like that not only would I leave it as is, I would not put a hood on whatever vehicle it goes in so everyone who ever wanted to weld could see what could happen if you practice enough.
Old 02-08-2015, 12:32 AM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 is a splendid one to beholdbobj49f2 is a splendid one to beholdbobj49f2 is a splendid one to beholdbobj49f2 is a splendid one to beholdbobj49f2 is a splendid one to beholdbobj49f2 is a splendid one to beholdbobj49f2 is a splendid one to beholdbobj49f2 is a splendid one to behold
I'll have to be the deserter, I'd dress them up and make them smooth. I am also the type that doesn't like "patina" finishes.
__________________
Old trucks, it's a sickness-one I hope they never find a cure for!
Bob Jones--Fat Fender Aficionado--FTE member since '96
49 F-2 pickup/48 F-1 panel truck
48/51 F-4 flatbed (2 in 1)/49 8N tractor
www.fatfenderedtrucks.com
Old 02-08-2015, 05:27 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to behold
Chuck Frank
I'd have to grind them smooth so it looks like one piece, especially for powdercoating. Powdercoating raw welds will make it look "crude" IMHO.
__________________
Passionate about autocross racing!
1956 F100 Panel "GRACIE"
2007 Solstice GXP racer, the "KRAZED KANARY"
Third place finish 2009 SCCA National Championships
Old 02-08-2015, 08:33 AM
Marauder2004's Avatar
Marauder2004 Marauder2004 is offline
Marauder2004 is gaining momentum as a positive member of FTE.Marauder2004 is gaining momentum as a positive member of FTE.
Nice work! That will look really sharp on the side of that 300. I would like to have that kind of talent. I would be more inclined to grind them especially if you want a nice paint finish.
__________________
Howard
1948 Ford F4
1992 F-250 HD 5.8 4x4
2004 Mercury Marauder 32v DOHC - sold in June. Don't create a screen name after a car you might sell!
1969 Marquis convertible, 429
Old 02-08-2015, 09:19 AM
I tend to agree, it just feels "unfinished".
The outer edges will not be an issue to dress and metal finish.
How about the fillets around the bungs and flanges? What is the best way to get them finished down?
I use a carbide bur, and a sanding drum. With this approach I still tend to "gouge" some places and leave rough marks. It is not typically an issue though because a good primer or a little filler will hide them. But in this case I cannot use it.
So, what's your recommendations on tooling?
__________________
1956 F100
Old 02-08-2015, 12:16 PM
gerrymoe's Avatar
gerrymoe gerrymoe is offline
gerrymoe has a good reputation on FTE.gerrymoe has a good reputation on FTE.
You have put alot of work into that project and should be commended for it. IMHO I would do the additional time of finishing the welds. Make the curves look like they flow and the edges roll. 8pc Dual-Cut Carbide Burr Set - 1/4inch Shank
Cylinder Porting and Finishing Kit
1/4"" 90 Angle Die Grinder 1/4"" Medium Die Grinder
Go slowly with light pressure and you will have a nice looking finished pc ready for the finish
__________________
Old 02-08-2015, 01:25 PM
It is 16 ga. so i will not be able to really "roll" the edges. Just knock some of the peak off of them....
Similar Threads
Replacing vulcanized rubber for Polyurethane (F-1000) A lot of pics. Drosssor51 1987 - 1996 F150 & Larger F-Series Trucks 13 01-21-2015 03:41 PM
Is this stock?- other than the Rancho shocks Truckie256 Super Duty & Heavy Duty 13 01-03-2015 09:09 AM
What is this fuse ScrewIN Electrical Systems/Wiring 10 12-08-2014 04:41 AM
Caution Ford GT Porn chruby99 General Automotive Discussion 6 12-01-2014 06:36 AM
TRAIN WRECK engine bay, HELP. Warning Pic Heavy! wintertruck87 1987 - 1996 F150 & Larger F-Series Trucks 28 11-21-2014 11:34 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
