Should I grind and finish these welds or leave them be???
#62
The pressure test with water vs vacuum serves several purposes......
This is for a blower, and will see possibly 20 psi, 50 psi gives me a safety factor of 2.5, which I like.
Using water with air pressure vs just pressure keeps it from EXPLODING and sending shrapnel everywhere should something happen. Pressurized water does not store as much energy as air or vapor.
Water pressure will also bead up at any leaks, I can wipe it off, and immediately hit with the welder, and move on to the next without having to unload/reload. Or I can mark them pretty easy if I so choose.
Being able to weld it under pressure is also the reason I am choosing to use water versus alcohol or gas. I just don't want to have to deal with the vapors should I find some spots needing welded.
#63
#65
emeraldcoupe
15
05-09-2015 08:21 PM
65fordguy
09-19-2010 02:42 PM
