1974 F-100 Engine/Transmission Swap
#31
Thanks! I actually bought a remanufactured AOD from a transmission shop. It's the same thing that would've been in a late-80s truck or Mustang behind a 302... reman has the later-year factory improvements to strengthen it too (e.g. later-model OD band, etc.). If mine had been a manual truck to begin with, a Z-spec T5 would've been my choice, but I didn't want to take on an auto-manual swap. It has an FMX in it currently, though I imagine it would've been a C4 from the factory.
I got the Lokar shift linkage kit for it so I could orient the gear selector arm to my liking. Installed that tonight too, just didn't think to take pictures. Wasn't too hard - the directions are actually pretty good.
#32
The other day, I was mocking up the air cleaner to get vacuum line lengths figured out, and realized the one I have from the stock 2150 carburetor won't clear the 4180 I put on it. So, I procured a dual-snorkel 18" unit off a mid-80s Mustang and painted it to match the engine. The 302-4V decal was only $4 on eBay so I splurged.
#33
Couldn't find a good source for intake preheater exhaust shrouds to go with the dual-snorkel air cleaner, so I rigged something up - took a 3" galvanized Y fitting and cut it in half down the middle with an angle grinder, then 3" to 2" exhaust reducers.
Not the prettiest thing ever from down below, but should do the job, and won't look too bad from up top. I'll rotate that passenger side one to a better angle when I actually install them and tighten the nuts - they're just sitting in place for now. Haven't decided yet whether to paint them or leave them as-is (galvanized + stainless w/ aluminum tape)
#34
Why not make some that are full length out of sheet metal with a simple 90* bend, would double as a nice heat shield.
Have you looked into coating the headers?
After being impressed by it on a buddies built Fox Body I did my headers with Cerakote. It's reasonably priced, you use a HVLP gun to spray it on then bake it for a while.
#35
#36
As is with most things, doing it yourself is always cheaper.
My buddies car is a Vortech blown 302 putting 593 to the pavement and at idle you can almost grab the headers with a bare hand.
I'm keeping an eye out for a cheap oven to put in the shop as Cerakote has tons of coating products and I'd like to try some of my own Powder Coating.
#37
Nice! Looks like they've got some air-cure products too (no oven required, which makes it more likely to pass the wife test); do you have any experience with those?
I spent a couple hours today getting things unhooked so I'm ready to pull the clip - have a couple friends scheduled to come over tomorrow to help with that. I think the rest of today will be mowing the lawn and straightening up/organizing in the garage to make enough room to keep the front clip in there while it's off the truck.
#39
#40
#41
#42
#44
