1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2012 F250 Lariat Water Drip on A-Pillar
Old 02-07-2015, 12:35 PM
burtpolson's Avatar
burtpolson
burtpolson is offline
When it rains I get a drip inside on the driver's side A-Pillar (front left post). The water drips off the pillar grab handle to the floor. When it wasn't raining I took the garden hose with the pressure spray and selectively sprayed different areas on the roof, sunroof, windshield and driver's door and window that could cause the drip, but could not duplicate. I inspected the sunroof drains and even shot air into them the best I could in case they were clogged. I am not sure what to try next. Any suggestions?
Old 02-07-2015, 02:18 PM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
If you are still under warranty then I would take it in. Take a picture or take it when it rains so they can see if.
Sun roof is what everyone always talks about.
Old 02-09-2015, 09:13 AM
FordService's Avatar
FordService
FordService is offline
Official Ford Rep
Hi burtpolson,
As Scott suggested, a trip to the dealership is a great next step. How many miles are on your truck?
Crystal
Old 02-09-2015, 04:33 PM
burtpolson's Avatar
burtpolson
I have over 100k miles on the truck...no more warranty. I am going to try a can of compressed air shot into the drain holes and see if that helps...maybe get a better seal with the air than I did with my compressor.
Old 02-10-2015, 01:31 PM
droldsmorland's Avatar
droldsmorland
droldsmorland is offline
Do you have the FCC cab clearance lights? If so they can leak too. Soak the cab down using a spray bottle with a mix of dish soap and water in it. With the HVAC fan blower on medium to high and the windows rolled up tight start spraying around the suspect areas. You will see it bubble. Keep in mind these cabs are not 100% water tight so you will see various leaks at the door seals etc...but there should be none on the roof. Said leak should show its ugly self right away.
Old 02-10-2015, 01:35 PM
burtpolson's Avatar
burtpolson
No clearance lights, but there is the GPS antenna. That is a good idea you have and will try it.
Old 10-29-2020, 08:10 AM
PatrickStapler's Avatar
PatrickStapler
PatrickStapler is offline
Apologies for reviving an old thread, but I just discovered a similar problem on a 2015 F250 I just purchased. It rained fairly hard last night. On the way to the gym this morning I had water dripping on my leg. I shined my phone light on the driver side a-pillar and saw water running down the dash panel. I also remember my neighbor having this same problem in a F150 a couple years ago. Does anyone, know the root cause of these issues? Is there a possible TSB on this problem?
Old 12-15-2020, 12:51 PM
droldsmorland
See post #5.
Update on mine:
Just a few months ago I was going through a car wash when one of the FCC lights blew off. All of the screws were cracking the black bases and were finger tight 2 were altogether gone.
So all were junk and each light had rust bubbles around all lights on the roof surface! This is a fairly clean 2011.
Had to take it to a body shop. They pulled the lights, windshield, antenna, and headliner. Stripped the top, killed the rust, repainted, and installed new lights & windshield. Looks beautiful with new glass paint & lights.
The body shop (a real good one) said he put heavy-duty calk on each light base and between the lens and base. Same for the satellite antenna. He said the ford gaskets are useless when new. He has been in business for 40 years and said only recently he has witnessed this problem with the roof penetrations for the lights and antennas.
So Im in good shape now a thousand lighter in the wallet. I thought was a good price for all the work.
Old 12-15-2020, 02:05 PM
wwhite's Avatar
wwhite
wwhite is offline
Yes, there should be, but maybe not. I took mine back to dealer within a couple years.
I had a 2010, water leaked at passenger side holy s*@t handle.
The issue was the GPS seal, dealer replaced. I'm sure the new GPS seals are better.
(why cut a hole in a perfectly good roof?)
Old 12-15-2020, 05:52 PM
TB250's Avatar
TB250
TB250 is offline
I know this sounds crazy, but chances are it's the CHMSL leaking. I pulled mine out and re-sealed with some butyl caulk - no more dripping from the grab handle on the A-pillar.
4inchlovin
24
09-16-2008 06:05 PM
zahntoid
2004 - 2008 F150
11-14-2006 07:17 AM
jeffreysw
08-17-2004 12:02 PM
Ribkick
1997 - 2003 F150
12-22-2003 12:20 AM
Quick Reply: 2012 F250 Lariat Water Drip on A-Pillar
