Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1967 - 1972 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Crate Engine
Old 02-07-2015, 09:10 AM
schmiddw schmiddw is offline
schmiddw is starting off with a positive reputation.
Crate Engine
The 390 in my '67 bent a pushrod shortly after installing this used engine. I have to check the timing chain. Any chance if the timing chain went the engine could still be serviceable when fixed? If not anyone had good luck with crate engines? If so from where?
Old 02-07-2015, 01:15 PM
f100today's Avatar
f100today f100today is offline
f100today is gaining momentum as a positive member of FTE.
What is your budget? You typically get what you pay for.
__________________
67 F100, 4BT cummins, Compound turbos, 700R4 OD tranny, Custom dash, mustang II, QA1 coil overs, One piece windows.
build thread: http://www.ford-trucks.com/forums/12...ver-build.html
Old 02-07-2015, 01:25 PM
CougarJohn CougarJohn is offline
CougarJohn is gaining momentum as a positive member of FTE.
I do not believe that a bad timing chain can bend a push rod on these motors.
Old 02-07-2015, 02:05 PM
Quote:
Be advised that shills come into these sites posting innocent questions for references to their products. The reference comes back in. You can guess what it is.
If you buy a crate engine from any internet reference you assured of getting something with a top-quality Shanghai rattle-can paint job on something. You bust your **** to R and R the thing to learn the hard way. Like on teardown.
There is no cheap way to rebuild these old motors. Good labor gets paid a wage to keep them living happily in the local environment. If you want to get a good rebuild, ask around town. Find the best guy. Cheap prices get you cheap parts with a high school cluck running the boring bar. Take the engine in and insist on seeing the box for the rebuild parts and the gasket set. I have even been in shops where I watch the crank dropped into a properly installed rear seal. I have knowledge, but a rotten spine.
Mistrust.
Old 02-07-2015, 02:13 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to behold
Carolina Machine Engines Rebuilt Engines and Rebuilt Motors from CME
Old 02-07-2015, 02:57 PM
RichS2659 RichS2659 is offline
RichS2659 is starting off with a positive reputation.
390? Used engine? How did you know it was a 390? Did you stroke test it to begin with? Is it a case of "390 on sale day, 352-360 any other day"?
Old 02-07-2015, 03:18 PM
instig8r63's Avatar
instig8r63 instig8r63 is offline
instig8r63 is gaining momentum as a positive member of FTE.
Bent pushrods are generally caused by a tight, dry or gummed up valve guide.
__________________
Bobby
Old 02-07-2015, 04:16 PM
351Cleveland C4's Avatar
351Cleveland C4 351Cleveland C4 is online now
351Cleveland C4 has a good reputation on FTE.351Cleveland C4 has a good reputation on FTE.351Cleveland C4 has a good reputation on FTE.
Or a locked up hydraulic lifter.
__________________
Garrett, first prince of the Bumpside Kingdom.
'71 F100, 351C 2V, Edelbrock Power Pack, AOD trans, 4.11 Yukon LS
and 7 other fords...
Gas is Great, but Diesel kicks Gas!
Old 02-07-2015, 04:20 PM
Quote:
2000-3000 I am really looking for a stock rebuild that can run on unleaded gas. I've had the truck for 18 years, and I am trying to finish, up the projects swapped out an old engine that had no compression with one from an rv with good then a pushrods went a couple of days after install and working through old gas.
Old 02-07-2015, 04:22 PM
From my local salvage yard. It came out of a bump side rv. It had good comprehension. The old 360 I had in it had none.
Old 02-07-2015, 04:25 PM
instig8r63's Avatar
Hydraulic lifter preload is generally .020-.050, not enough to bend a pushrod. What usually happens is the valve gets hung up in the guide and the lifter tries to open a valve that won't move. The weakest link is the pushrod.
I guess I was wondering if a national auto parts chain with a warranty is an okay to do. I don't know much about engines, I'm just trying to get this truck as a daily driver in the summer. I have had it garaged 18 years
Old 02-07-2015, 04:27 PM
My friend who swapped it worried it was either the timing chain or cam shaft. Only one pushrod bent. Obviously if it is the cam I'm in trouble.
Old 02-07-2015, 04:28 PM
instig8r63's Avatar
It is neither the cam nor the timing chain.
__________________
Bobby
Old 02-07-2015, 04:29 PM
There was some lifter clatter earlier upon start up because of some dirt, but that cleared up after adding some additives.
Similar Threads
How can I tell if my 351M.... kuch73 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 0 03-26-2011 02:50 PM
Crate Engines bsteele52 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 12-29-2008 10:17 PM
New crate or a rebuilt junker? BlueOvalDrifter88 1987 - 1996 F150 & Larger F-Series Trucks 6 05-24-2005 07:58 AM
engine Change what's better? tcb89 1978 - 1996 Big Bronco 12 03-15-2005 08:07 PM
Crate Engines GeneStoner Ford Inline Six, 200, 250, 4.9L / 300 24 12-27-2002 05:49 PM
Tags
bent pushrod
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
