Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1967 - 1972 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
71 F100 - Rear Wheel Bearings
Old 02-06-2015, 11:43 AM
Corkwheats Corkwheats is offline
Corkwheats is starting off with a positive reputation.
Hey Guys,
I have some serious leakage from my rear axle seals.
My mechanic says we should replace the seals, wheel bearings, and then the rear drum brakes.
What is the top of the line wheel bearings & seals that I can get for this truck?
Thanks,
Bob
__________________
1971 Ranger XLT
390 C-6
Holley 600
Oregon Custom Grind Cam
9.5 to 1 C.R.
Flotech Headers
Old 02-06-2015, 11:57 AM
JEFFFAFA JEFFFAFA is online now
JEFFFAFA has a very good reputation on FTE.JEFFFAFA has a very good reputation on FTE.JEFFFAFA has a very good reputation on FTE.
There is also a retainer collar that presses on the axle shaft to hold the bearing on. If you give me the axle tag number off yours I can look to see which bearing it takes. Ultraranger went through an escapade recently on his thread.
__________________
KING (2) of the Bumpside Kingdom.
Trucks aren't Cool unless the tailgate handle swings..........
Never be afraid to try something new. Remember, amateurs built the ark, and professionals built the Titanic.
Old 02-06-2015, 04:28 PM
ultraranger ultraranger is online now
ultraranger is gaining momentum as a positive member of FTE.ultraranger is gaining momentum as a positive member of FTE.
Most F100 Bumpsides had Ford 9-inch rear ends. Some had Dana 44 rears. Some ('68-'72) had 9-3/8" rear ends with 31-spline axles --and as I found out more recently, the 9-3/8" rear ends could have TWO different 31-spline axles.
One with a 1-5/8" I.D. by 3-9/64" O.D. axle bearing (3,600 lb axle and Traction-Lok differential) or one with a 1-17/32" I.D. by 3-9/64" O.D. axle bearing (3,300 lb axle with an open differential).
I have a '69 F100 that had 28 spline axles but I converted it to 31-spline axles from a 9-3/8" (open differential) rear end when I installed a Ford 9-inch N-case 3rd member with a 31-spline Traction-Lok differential. The axle bearings are 3-9/64" O.D. by 1-17/32" I.D. (for a 3,300 lb axle).
I got the axle bearings and seals for my setup from NAPA. The bearings were regularly $60-something each but, they gave me a discount which made them $48.00 each.
http://www.ford-trucks.com/forums/13...l#post15054362
Old 02-06-2015, 05:41 PM
351Cleveland C4's Avatar
351Cleveland C4 351Cleveland C4 is online now
351Cleveland C4 has a good reputation on FTE.351Cleveland C4 has a good reputation on FTE.351Cleveland C4 has a good reputation on FTE.
I bought NATIONAL bearings and seals from oreillys.
__________________
Garrett, first prince of the Bumpside Kingdom.
'71 F100, 351C 2V, Edelbrock Power Pack, AOD trans, 4.11 Yukon LS
and 7 other fords...
Gas is Great, but Diesel kicks Gas!
Old 02-06-2015, 08:33 PM
Quote:
That's what I had put on my 28-spline axles nearly four years ago, when I went through the brakes, bearings and seals at all four corners.
The (SKF) axle bearings I just recently bought through NAPA are the same size for my 31-spline axles as what fit my 28-spline axles.
I didn't have any problems out of the National bearings during the time I ran them but, the more expensive SKF bearings I just got are a much better quality than what I had.
The bearing retainer rings are also about twice as wide (beefier) than the rings that came with the National bearings. --They would have nearly twice the surface area and grip on the axle, compared to the rings of the National bearing set I had.
Old 02-06-2015, 09:02 PM
Well that's what I got, and I'm running them. I guess I'll find out if I ever have to change them again.
So far I've loaded them up heavy and gone down the highway once. I'm sure it will happen many more times in the next 40 years.
__________________
Old 02-10-2015, 06:35 PM
Thanks so much, guys. I like the sound of the heavy duty SKF.
I do quite a bit of towing/hauling here on the farm.
My 71 Pick Up has a 9" Rear End, with a 28 Spline.
I would give the tag info on the rear end, but believe it, or not - it's incorrect (not the right one).
This Spring all this is going to get done. Then, we put in the 3.5 to 1 ring & pinion!
Thanks,
Bob
__________________
1971 Ranger XLT
390 C-6
Holley 600
9.5 to 1 C.R.
Flotech Headers
Old 02-12-2015, 06:01 AM
gfw1985's Avatar
gfw1985 gfw1985 is online now
Amatuer Restorer
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
This may be of some help:
__________________
66 Bronco Half Cab, 203ci I6, CI aluminum head and intake, Isky 256/256 cam, Keith Black pistons, Clifford header, Holley 390cfm 4v, 9.7:1 comp, DSII ignition
55 F100 Build in progress http://www.ford-trucks.com/forums/13...100-build.html
Similar Threads
Rear Axle Seals Leaking Corkwheats 1967 - 1972 F-100 & Larger F-Series Trucks 19 10-31-2014 12:53 PM
How to remove ESOF knuckle seal? Duzitall 1999 - 2003 7.3L Power Stroke Diesel 26 02-20-2012 12:43 PM
1977 dana 60 rear axle seals 77f2504by4 Clutch, Transmission, Differential, Axle & Transfer Case 2 05-11-2005 09:38 PM
shop time estimate? bad axle? yukonhighboy 1978 - 1996 Big Bronco 0 12-07-2003 10:59 AM
2.8L rear main bearing wedge seals?? WRC Bronco II 1 12-02-2003 11:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
