Poor heat in my new 2015 F-350 4X4 Diesel Lariat
I have run under a 50 50 mix in my vehicles for 35 years. Never had a heat issue, a coolant based failure, or cooling related problems. I find it funny that coolant boils at 240 degrees at atmospheric when water boils at 212. IF water was the better coolant, we would all be running methanol/water mixes just for freeze protection...just because "google" says something does not counteract 35 years of experience.
I have 5 bucks your trucks problem is a failed thermostat...not the ratio of water to coolant in your cooling system.
I thought you were saying you were running 90 percent antifreeze to 10 % water. If you are saying the reverse that is not good either as antifreeze has the secondary purpose of lubricant and antirust.
It is not just one Google entire that supports 50/50, it is all of them.
This is my last comment on this topic.
I do agree I believe the problem to be the thermostat, but the ratio was a good point to check.
DONE.
Just got the truck back, no supplemental heater purchased, for $60,000 I should have heat.
code was P207F, they rerflashed the computer.
They state that the poor heat is normal.
They state they were not able to duplicate the false backup obstruction alarm.
Suggested I call Ford Customer Service.
Ford customer service will not do anything because the work order says operating within specification
Boy am I unhappy. No new Fords for me in the future
Couple things I have noticed with my truck...2008 f250 6.4 Diesel.....Back up sensors...any salt or road grime or snow or ice on any of the sensors will initiate a false reading and activate the alarm (which always makes me wonder how these cars that park themselves do in the winter)
Climate control while in the "auto" mode always has a delay activating the fan in the cold...not really sure why...however I assume it's to let some heat build up in the engine first. If you take it out of "auto" mode..ie use the fan speed selector to turn the fan on, it'll come on instantly and start blowing air warm or cold.
As far as you lack of heat issues....They make winter front grill covers for these trucks for a reason. When I first got my truck I didn't have one....in cold weather heat in the cab sucked and it never really reached operating temp even on long drives. However put on the winter front grill cover....always reaches operating temps no matter how cold it is outside....and heat output in the cab is 100 times better.
Where did you get your cover.
Ford dealer as stated heat is within specs. I have discovered what they were doing was turning the heat out off auto mode and cranking it all the way up, in in fact you do get some heat that way.
This truck is equipped with dual climate control and when it is set to 76 degrees the fan never ramps up and the heat coming out of the ducts is at best luke warm.
It has now been back to the dealer twice fro this problem, it appears they think I am complaining because I like to.
Time to buy a foreign truck
The auto mode may keep the fan speed lower if the coolant temps never get into the operating range....I know with the winter front...my auto mode keeps the truck quite toasty now to the point the wife no longer complains about being cold lol. I got my winter front off Ebay....its Ford OEM.....you can get it from the dealer as well.
As far as your backup sensor, it is pretty hard for a tech to get them to duplicate when your problem is more than likely frost on the sensor, and they are working in a warm shop. Before getting in your truck to drive, take your gloved hand and wipe the frost off the sensor.
Foreign trucks are like consumer reports........overrated! My Super Duty can haul 2 foreign trucks, my jeep and my RZR, all at the same time!
Here's what I have done with mine. I have cardboard in front of the radiator( the winter fronts I was finding a month ago required stick on snaps and the grill needed to be at room temp) I turn the dual control off and turn the heat selector all the way up usually on defrost or the floor/ defrost mode. This truck will roast you out if given the time. If I let it warm up for 15 mins. before I drive the temp is comfortable. I also have the heated seats ( which my wife loves) that help make me or you a bit warmer.
Crystal
#28
There are some additives you can add that allow faster heat transfer in water, this will allow the temp to decrease by 5-15 degrees. That said its still governed by the thermostat. If its 180 F then that is when it opens, 180 is 180 regardless of how fast the water is able to heat transfer.
Air Bubbles: Yes they can be there and be there on a brand new car. Friend of mine bought a new car and drove from the dealer to my house to show it too me. It was overheating when he pulled in the driveway. I suspected an air bubble. I hosed down his engine and radiator til it was cool enough to remove rad cap. Fired it up and let it run with heater on till he reached oper temp. I kept adding water to it. Had him rev engine a few times and suddenly water level DROPPED, filled it to full, replaced cap and he never had another issue.
#29
I have sent a PM Thanks
Concur:
Coolant was tested mixture is 50/50
#30
