Identify this drip
Identify this drip
Hey all, I have had this leak just inside my right front tire for some time and I just figured it was condensation from the AC.
The other day I noticed it's leaving a stain on the driveway and I haven't run the AC in months - hmm..
Today after arriving at work I noticed there's a stain there as well. I stuck my finger in the drip and it seems to be anti-freeze (slippery water) and not oil. I popped the hood and the reservoir shows coolant at the full mark.
Any tips on what could be the culprit?
Most newer vehicles use the AC compressor to remove moisture from the inside air to help prevent the windows from fogging up. It's possible that's what you're seeing still. Try throwing some cardboard and paper under the drip to see what's actually dripping to rule out picking anything up from what's already on the ground.
IIRC the A/C runs for Max A/C, A/C, Dash and Feet, Floor and Defrost, and Defrost settings (pretty much all of them except Dash Only, Floor Only and if it's less than 50F outside)
I would only consider a fuel leak if it was on the axle tube too. That's where mine dripped at when the fuel bowl drain valve O-rings were done for.
Thanks for all the replies.
I'm not certain it not fuel. As I dipped my finger into it and lifted, it formed a drop like water (if you know what I mean). It was slippery though when I rubbed my fingers together so that felt like antifreeze.
My sniffer doesn't work so good though - maybe it is diesel.
I'll crawl under this weekend and report back.
I believe the larger puddle is morning dew dripping off the cab
It really sounds to me like a coolant leak at the heater valve or heater core going into and out of the cab. It is dripping exactly in the same place as mine when I noticed my coolant lines leaking in the extreme cold we had two weeks ago. Tightened up on my worm clamps and all is good now... except I have another minor coolant leak to chase from somewhere else that has not yet become obvious to me.
If you have a piece of cardboard, tape a piece of white paper on top of it and place it under the leak to determine color. Make it a large area and place a brick or stone on it so you can leave it overnight without it blowing away.
BTW... what color is your coolant?
Old school, is now speaking... you can touch the tip of your tongue to it and taste it very slightly to check the source... you don't have to swallow, and that small of a taste will not be hazardous regardless of it being fuel or coolant.
Tugley, your no drip (if that's what you meant)
