Fuel problem; - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Fuel problem;
Old 02-04-2015, 06:07 PM
RUSTY50F1's Avatar
RUSTY50F1 RUSTY50F1 is offline
RUSTY50F1 is starting off with a positive reputation.
Fuel problem;
I put a 400 in my 79 Bronco. I replaced the fuel tank, the filter under the truck, new fuel pump. I put a clear glass filter in the line just before the carb. But if the truck sits for a few days the gas goes back down the lines and it takes a while of cranking to get it back to the clear filter and into the carb for it to start. What could be causing this to happen??
Old 02-04-2015, 07:09 PM
gatorfor88's Avatar
gatorfor88 gatorfor88 is online now
gatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputation
Fuel pump is supposed to have a check valve to keep it from bleeding back down. Might spend the extra$$ and get a new Holley pump.
Old 02-04-2015, 08:02 PM
RUSTY50F1's Avatar
I've noticed a rattle noise in the front of the motor. Sounds like it is coming from the drivers side. Maybe the new fuel pump isn't any good. But it pumps. Just seems like it has to crank a long time to get the fuel up.
Old 02-05-2015, 06:03 AM
gatorfor88's Avatar
Its doubtful but it could be something to do with the eccentric bolted to camshaft that drives the fuel pump.
Old 02-05-2015, 07:47 PM
RUSTY50F1's Avatar
Think I will just put an electric pump on it and forget about it. Cover the fuel pump hole with a plate. I think 10 to 14 psi is about what I need. Am I right?
Old 02-06-2015, 06:00 AM
gatorfor88's Avatar
way too much for carb,way too little for f.i. carbed should be between 4-8. depending on carb. I have heard edelbrocks are touchy about fuel pressure.
73 f-100 V8 390 wglogg 1973 - 1979 F-100 & Larger F-Series Trucks 2 09-12-2016 11:37 PM
no gas 2 carburetor Jake Wenzinger 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 67 02-21-2016 04:19 PM
Inline Fuel filter, cleaning gas tank tomwhatley 1973 - 1979 F-100 & Larger F-Series Trucks 7 09-27-2014 09:21 AM
Fuel Pressure/ Pump problem miketaheny 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-21-2014 08:47 AM
fuel filter goes dry, need some diagnostic help dfwrider 1973 - 1979 F-100 & Larger F-Series Trucks 29 10-06-2009 03:05 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
