AOD Neutral Safety Switch
Has anyone hooked up their neutral safety switch when using the AOD? Is it more of a safety item than a necessity? In other words, if it isn't hooked up today will I not be able to start the truck and drive it? Just trying to see what I have to have at a minimum in order to fire this thing up.
Thanks in advance.
Thanks in advance.
Here's an article with pictures that might help. My Restomod Mustang 1966 Modification and Restoration Adding 12v power to center console
I hooked mine up. Just wired it in series with my starter button...easy.
25 years ago, I put a 351W/C6 combo into a '51 F1 Panel and didn't hook up a neutral safety switch. There were a couple of times when I started it in gear accidentally - usually after a stall or when you stop and are just talking to someone for a minute and turn the key off. Easy to forget, actually. The neutral safety switch is a no-brainer on the AOD since it's already there (the C6 would've required I fabricate something).
I'm talking about the switch on the column actuated by the shift leaver that prevents starting outside of park and neutral. (1973 F100)
I've read where a pin is put into the back and the switch is set in place with the transmission in neutral. I tried that but the truck still starts in all gears.
