6.2L V8 Discuss the 6.2L V8
Cold start whine
Old 02-04-2015, 11:42 AM
T diesel's Avatar
T diesel
T diesel is offline
Cold start whine
Disappears @ around 2 1/2 minutes. Starts at around 10 seconds. 6F degrees out.
20,000 mi. fresh mobile 1.
Any ideas before I go to the dealer?
Old 02-04-2015, 02:31 PM
mikereidjr's Avatar
mikereidjr
mikereidjr is offline
Mine does the same it always happens when it gets cold with this truck unless I plug it in.
Old 02-04-2015, 03:26 PM
ATP Pilot's Avatar
ATP Pilot
ATP Pilot is offline
my guess...alternator under heay load
Old 02-04-2015, 08:22 PM
hoss66's Avatar
hoss66
hoss66 is offline
My truck has been doing the same thing when it's cold. Keep us updated if you figure out what is causing it. Thanks
Old 02-04-2015, 09:16 PM
Vforce's Avatar
Vforce
Vforce is offline
Mines doing the same thing! 25,000 mles.Only when its cold. I even park in the garage.
Old 02-05-2015, 07:20 AM
fg250's Avatar
fg250
fg250 is offline
Power steering pump is what it sounds like to me. I've had a few different trucks do this.
Old 02-06-2015, 06:07 AM
bootit's Avatar
bootit
bootit is offline
I have a 2012 6.2 that I bought in Oct. 2012. This truck has made the same noise since it was new and the weather gets cold. The dealer has had the truck 12 times and replaced, belt, pulley, alternator, power steering pump,tensioners. This issue has been so frustrating! They have an engineer involved finally! Good luck getting it fixed. Please let us know if you get it fixed.
Old 02-06-2015, 10:52 AM
T diesel's Avatar
T diesel
T diesel is offline
Well they called and said "it was the idler pulley."
I pick her up tonight.
We'll see!
Old 02-06-2015, 02:52 PM
bootit's Avatar
bootit
bootit is offline
Good luck with that.I am on my third set and still making the same noise.
Old 02-06-2015, 06:09 PM
hoss66's Avatar
hoss66
hoss66 is offline
It got up to 35 degrees today and my truck didnt make the noise at all, i think it is definitely temperature related.
Old 02-06-2015, 07:04 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
We'll see!
Thanks for reporting back. Hope this does the trick for you...because that is really a terrible sounding noise. WOW!!
biz
Old 02-07-2015, 07:18 AM
T diesel's Avatar
T diesel
T diesel is offline
Well, started her up at 14 deg.F and no whine.
Old 02-07-2015, 08:28 AM
Slowpoke Slim's Avatar
Slowpoke Slim
Slowpoke Slim is offline
Mine's been doing it since day 1. Only when it's cold out, definitely temp related.
Old 02-07-2015, 04:32 PM
jimd1050's Avatar
jimd1050
jimd1050 is offline
Worry later? IT IS LATER!
Wow!
Glad I found this thread... my 2015 did it for the first time yesterday! I almost shut it off thinking something was "BAD" wrong! It was the coldest day yet that I have actually had to start it up - it was like +7 with a windchill of -5. I let it go and it quieted down a bit from the initial sound and then finally went away after about 6 or 7 minutes. As one other person stated, reminded me of a power steering pump with not enough fluid. I have subscribed to this thread! Truck only has 1800 miles on it...
Regards,
Jim D
Old 02-07-2015, 07:14 PM
T diesel's Avatar
T diesel
T diesel is offline
I'm starting to get sinking feeling that bootit may not be the only
one with a chronic "can't fix" problem. I always remote started mine
from in the house. I'll be paying attention to see if it comes back!
Quick Reply: Cold start whine
