Fuel Additive: what are you guys using?
#61
#62
#64
I used Seafoam for 9 years. Put two cans in the fuel about every 5th fill up and two cans in the motor just before oil change. 123k and never had any turbo or injector problems. Just switched to Archoil 6400-D. Put 2 bottles in the X for initial treatment then 1 bottle every 5th fill up. Certainly seems to have better throttle response.
Ed
Ed
The two bottles of sea foam in the oil just before a oil change ,,,,, how many miles do u leave it in there before changing the oil ...... I want to try that , sounds like a good idea.
Thanks
Jamie
#67
#68
#70
I know this won't be popular on this thread but I have been using the EDT for a little over half a tank and it seems quieter on start-up and even quieter at operating temp (190 ECT/ 195 EOT). I had been using bio while the price was $2.14 but now it's back up to $4.21. Ran a tank of straight diesel and definitely could tell the difference. I need to download an app to get the decibel reading cold and after up to temp on this tank, one more straight tank and then then with the Stabil sample that I received. Any suggestion on a decent decibel app?
#71
#73
The bottle says "treats up to 150 gallons". My Ex has a 44 gallon tank - so I figured 150/44 = 3.4 and I don't run until it is empty, so I put 25% of the bottle in each fill-up (5 oz). But I'm an engineer and therefore use math probably more than I should.
#74
LOL I need a sign too it will say ( wife please keep your stuff off my work bench) thanks Husband I use about 4oz every fill If you guys have a Cal Ranch supply they have Howes, Diesel Kleen on sale for 11/12.00 buck for a large bottle also Stanydine for 14.00 large bottle, the Only one close is Carson Nevada and Arizona those are the only two Stores that I have ever been in , Love that Place
#75
Did a little video on db readings while using the Cetane Boost.
https://www.ford-trucks.com/forums/1...ane-boost.html
