Another oil cooler thread-deltas really matter with egr delete?
The oil temp you see on your monitor is the temp at the sensor. Its located in the oil system in a place that gives a generally accurate "overall" idea of the oil temp. At different places in the engine oil temps are much higher. +15° on the gauge doesn't necessarily mean +15° on the whole system and the gauge isn't showing the hottest temps the oil is reaching.
I ran my truck for a few months on a clogging cooler and saw 245° EOT a few times towing in the heat of summer (I know better now). The EGR cooler broke but the oil cooler didn't. I rolled the dice and got away with it (sort of). With the EGR delete you might do the same but I don't think anyone here is going to say it's ok. It's an expensive engine and the stakes are high. Good luck.
Thank you that's the answers I'm looking for!
The heat-I don't think 230-240 or even 250 should cause an issue
Cooling system pressure-again not sure this would cause an issue unless there was substantially more pressure in your system then there should be.
Now crap in the system "sandblasting" the oil cooler down to make it thin and then rupturing-that makes sense!
Just trying to get more of an idea how these things fail and how much longer I can run it (I'd like to get a couple more months out of it to use the coolant filter to get all the junk out of my cooling system prior to a new oem oil cooler getting installed)
2006 F350 4X4
I'm walking this exact road right now. It sucks BIG TIME.
It has already cost me 24 grand, because I had to buy another truck to drive while I fix mine. (I work oil field, so I drive all over the state. Didn't have time to wait on a new engine.)
Now I'm dishing out thousands to rebuild and bullet proof an engine, all because of the damned oil cooler.
I've already done a basic drain and fill 4-6 times with distilled water.
Go back and read my previous post in this thread. Roll the dice if you like. No one here will tell you it's a good idea.
Bless your heart. We're trying to tell you that running the truck with an iffy oil cooler is bad medicine. I did it, and I'm paying for it. Do what you want, but when your engine starts swapping fluids, it's all on you. No one here will endorse this course of action, because no one wants to be called out when you post up about ruining your motor.
Some people don't know this part of just ignore it.
The oil in an engine does 2 basic things and in out case 3.
1 Lubrication
2 Heat transportation/removal
3 hydraulic functions in the injectors and turbo.The turbo bearing
also floats on a cushion of oil if I recall that right.
But the one you need to think about and most just miss it.
That one is #2 Heat transportation/removal. Hot oil as it moves
through the block and any coolers move heat from hot places
like the pistons from the oil jets. You also remove heat from all
the bearing surfaces and then you get into the oil film and it getting
too thin to support the load that it's being put under.
Then on top of that the temp or EOT that you see is not the highest at
that very moment. You will see hotter oil on the piston skirt walls than
at the sensor.
Now for the when to replace an oil cooler. This is MY THOUGHTS on this
topic.
So long as you are below a point where the ECM is going to start making
corrections and you see a fast recovery from a heavy load I think you may
be safe. But you don't want to give it a big shove and push it right over and
past that top limit and have a melt down.
Sean
1 Lubrication
at the sensor.
topic.
Sean
2006 F350 4X4
The problem with a distilled water only flush it really doesn't do much of anything. The silicates and casting sang bond together and stick to the rough surfaces of the cooling passages. This requires some type of chemical flush that breaks up that bond and moves it out of the system by draining the system. However the biggest clumps will not dissolve right away and may remain for some time slowly breaking up because they have been softened.
Ergo the recomendation for the coolant filter to catch this stuff before it can clog your new oil cooler. The oil cooler has the smallest passages in the whole cooling system so it is easier to plug up than say the radiator.
Even the radiator can plug with enough trash and time.
#28
#29
Yes I am planning on having a shop do the oil cooler (I think I can do it but better pay a professional then screw something else up)
Thinking of going with an ipr coolant filter as it looks to be the best filtering one.
I've read numerous debates on vc9/restore flushes and whether or not to actually do them.
I'd hate to do vc9/restore then swap the oil coolers just to have the new one clog up with gunk from the flush. I only want to do this job once!
#30
The cooling system should be stable at this point and should not plug a new OC.
