2015 F250 / Leveling Kit
You have an F250? What year? They sit pretty level from the factory.
F350? They have a higher rear end from the factory and many folks raise the front up to make it level.
It is a 250. 2015. The FX4 seems to sit level but the 4X4 squats. And with a skid steer on a trailer the "Super Duty" squats another 3-4". So much so oncoming traffic flashes their lights to high thinking the Fords high beams are all ready on when they are not.
most of us who haul loads, GN or FW trailers have had to add something to keep the tail from dragging. air bags, stableloads, added springs.
That looks great, that is about the aggressiveness that I want with mine. Any issues with the 37's on the stock wheels, I am looking at using my stocks as well. Which suspension system did you go with? I like the components on the Ready Lift 4.5 inch kit. Also, with the 4inch lift is there any issues with ride rite air bag systems?
It has 1/2" spacers in the front. It would rub if you would cut hard without the spacers. I don't know anything about ride rite air bag systems.
It was hard to tell if your truck was squatting unloaded or loaded. If the stance while unloaded bothers you then that's another issue which involves more than just air bags.
Airbags with Lift...
2015 F250 Crew, Standard Box, 4x4, Diesel...
I measured my rear blocks at 3.5", on level ground (measuring to fender lip) my truck sits 2-1/4" higher in the rear.
Looking at getting the ReadyLift with 5" rear blocks and 3.5" front spacers so should make my truck sit about level. My concern is that at level rear will sag with load so am thinking about getting air bags to level it under load...any thoughts or feedback from anyone's experience with a similar setup? Also, how much does an airbag system raise the trucks rear when at minimum pressure? Thanks in advance for any info or insight!
You have the right idea. I'm using a 6" lift the front and rear are level as it sits. Hooking up to a trailer with some weight will make it squat and I use the airbags to raise it back up. I did measure it at one point and I think the Firestone airbags I have can raise the rear a solid 3" with the brackets installed in the correct spots. I'm not sure what pressure that is, I have two pressure valves on my onboard air that I just adjust until it's level.
Lifted F350 dually
Hello, I am very interested in what kind of tires you run and what kind of spacers you run? I have a 2015 350 and I would like to lift it and put bigger tires on it using stock rims.
2013 F350
Attachment 198147
2013 F350
Attachment 198148[/QUOTE]
2013 F350
Attachment 198147
2013 F350
