Can't get Warn locking hubs out.
Hello. While performing a brake job on a '93 4WD F250, I am dealing with removing front rotors in order to have them cut (i.e. rectified). I have not been able to remove the manual locking hubs. After taking out both inner and outer clips, there is a part with splines which slides in and out on the spindle, up to a certain point but it would not come out. I assume it is part of the locking hub, for I haven't reached the spindle nuts yet. I wish I could post a picture to show it better. Any idea on how to get it out, please?
Thanks for your time.
Rayner.
Rayner.
May be I didn't express myself properly: once you remove the cap and the outer retaining clip, the manual locking hub seems to comprise three parts:
1- an outer gear, bearing the threads for cap screws on its side.
2- an intermediate gear, inside part depicted in 1
3- an inner most piece that slides on the spindle, and it is held in place by the retainer clip at the end of the axle.
I have taken out parts 1 and 2 with no problem. After removing the retainer clip (i.e. the one around the shaft), for some reason part 3 refuses to come out. It is not stuck, for it slides along the axle about 1/4", but I don't see what holds it.
Sad that I can't post pics yet. It would clarify the whole thing in a blink of an eye.
Thanks for your time, folks.
icantdo55
07-19-2010 07:31 AM
XJeepGuy
12-07-2004 07:33 AM
