6.2 fuel needs
I've never put anything but reg (87 Octane), in mine, even when towing our trailer and never had a problem. If there's nothing wrong with the engine, and it's not re-tuned for the higher octane your just wasting your money IMHO. I have a 4X4 with 3:73 gears, so my mileage would be a little worse than a 2WD with 3:55's, but I'll give it to you anyway. 13 overall average, 16 HWY, and 8-10 towing 7500 lbs.
on
This is what Ford says about Fuel economy, F150 2014 :
F-150 Specifications
Highlights
horsespower: 411 @ 5500 rpm (6.2L V8)*
torque: 434 @ 4500 rpm (6.2L V8)*
Fuel Economy and Engine Highlights
Engine Type 6/2L
13/18/15 (4x2) 12/16/13 (4x4) 11/16/13 (Raptor 4x4)
(city/hiway/combined
*Using 93-octane fuel.
(got this info from: 2014 Ford F-150 | View Full Specification Library | Ford.com
Does this indicate you must use 93 octane ?
What does the owners manual say ?
I got a new F350 on order with the 6.2L .. I hope I don't have to use 93 octane..!
Highlights
Engine Type 6/2L
Highlights
Engine Type 6/2L
Highlights
Engine Type 6/2L
Highlights
Engine Type 6/2L
Highlights
Engine Type 6/2L
Denny
11.58 mpg avg with 3.73 gears on my 2011 350 cc sb. Trying to see how low I can get it. Idles about 30 minutes a day in the winter. Trying to see if I can't get my mileage to the same as the triaxle crane i used to run. 1.5mpg uphill downhill fully loaded or empty at least I knew how far I was gonna make it .
I'm thinking that it will run on 87 but to get the max HP you would need 93, on my F350 I was running high altitude 85 fuel out west and took a wrong turn and ended up at 700 ft, it ran fine but it did have reduced power until we filled with 87 and went back up into the mountains. With all the knock sensors I think it will adjust to about any octane.
Denny
Denny
That's interesting for sure Denny. So you're saying even though the 6.2 doesn't NEED 93 octane, it will adjust and actually benefit from it? Cause if it's a significant improvement, I don't mind paying for it. I ran a 91 octane tune in my '03 F150 for ten years, and loved it. I have decided to run this one stock though, at least until the warranty is up.
Denny
I'm a good listener but a lousy reader. I checked again and the manual said to avoid fuel less that 87 octane which is sometimes AVAILABLE in high altitude areas. Thanks for the correction. It seems like good advice when traveling to check the pump octane rating.
Denny
