EGR When Open Increases Idle? (solved)
on
No you're not doing it wrong but you do have a problem. Fresh air will cause the idle to increase because it is combustable while exhaust is not combustable so it will cause the idle to get rough or even stall the motor if the valve is opened too much. So with the EGR connected to the exhaust there should be no fresh air getting in, if there is you have a leak in the EGR tube and it needs to be replaced.
Thank you both!
That made the light bulb turn on, thank you. Of course, that makes sense. The test was performed with the EGR tube disconnected because I don't know of any other way to manually activate the EGR valve without a vacuum pump (something I don't have). I'm guessing if it had a leak, I'd hear it? I hear no leak.
Thank you both!
chavist93
01-03-2014 05:57 PM
nighthawk285
02-11-2007 03:02 PM
paulg
12-03-2000 12:20 AM
