f600 4x4 6door build
#48
On a plus note your fix of your cab mount looks great.
#49
I'm not a welder by any means.just learning. I did grind them out. Both of you are right. I sent photos to my brother too, he walked me through settings and they were as they should be. Then asked if there was a breeze?? I had a torpedo heater blowing in my direction, preventing the shielding gas from doing it job. As soon as I moved it my welds improved. I welded on third section of the body mount and the welds are much better. Thanks for the heads up! It would suck to have that fail. I'll get more pictures up of my (better) welds for critique.
#50
#51
#52
The Rockwell Twins! Axle rebuild pics
here are some pics of the axle rebuild.
this is a military top loader out of an M35 duece and a 1/2 overall it was in good a shape. came out of a running truck. just cleaned it up and replaced wheel cylinders purchased it from Chris at army 6x6. Great company!
this is the front steering axle out of a donor truck. you can see it in my photo gallery. Its a fdx75 Rockwell.
It appeared to be rebuilt and never used. <br/>fluid was like new along with Greece. We had to fix some damage to the axle end, looked like it broke an axle at some point. Once we did some die grinding we were able to get the axle seal to seat correctly. Hopefully resolving the leaking issue.<br/>
sandblasted and etched primed top loader waiting final paint. we also flipped the hubs to help alien the rear wheels with the front. we did this because I'm running single rear wheels
picture of two axles ready to go. heeeeaaavvvvyyy!!!!
#55
Yes, extremely heavy. I didn't take into consideration when starting this project the weight and size of these trucks and there components. Fortunately I was able to obtain a forklift for short money. Parts are definitely hard to come by too. I was able to source a nos wiring harness today. Good news for the 6door!
#57
You made it big time to the front page buddy. Congrats. Hope your project is going well. Awaiting further progress.....
BUILDUP F-600 4x4 Rig is Transforming into a 6-Door Dragon - Ford Trucks
#59
