clutch issues please help
How's it going? Yesterday after work I started my truck
And went to leave but the clutch pedal lost pressure
And went to the floor. I couldn't shift the truck into gear.
I checked the fluid it was a little low so I added some dot3
And tried to pump the pedal, it didn't come back.
Started the truck in 2nd and gimped it home.
I searched and read a bunch of posts that led me to the
Slave/master. Pulled the slave and cycled it by hand and
Had someone make sure the fluid didn't get too low.
The pressure in the pedal came back.
Reinstalled the slave and now the pedal only
Goes down halfway, not even enough to start
The truck.
Did I install the slave wrong? Other thoughts?
I plan to replace the master and slave but
If I'm just doing something wrong id like to
To figure it out.
Any help is much appreciated
Truck is. 1999 f250 7.3 <acronym title="Four Wheel Drive">4x4</acronym> w a <acronym title="ZF 6 speed manual transmission">zf6</acronym>
Thanks
<!-- / message -->
The truck.
To figure it out.
Thanks
<!-- / message -->
nah, your going about it the right way, but after a few mishaps, i found it easier to just replace the m/s assy (pre-bled unit) as a whole. However, im afraid that you just experienced a bent clutchfork. Remove the slave again and measure from the outside hole til the tape measure bottomes out against the fork. Should be around 2-3/4in...the permanent fix is the upgraded fork.
You pull the trigger on a pre-bled unit, go with Advanced Auto assy..p/n PF9021...its an all aluminum construction
Thanks a lot man ill check that measurement and look into that part number I appreciate the reply @timmyboy76
northernroots
06-22-2014 01:01 PM
Ole'Blu
08-11-2013 06:27 PM
churchsoundguy
21
05-26-2011 10:05 AM
rkozaczka
02-04-2007 05:11 PM
Bubbatruck
04-12-2006 01:10 AM
