Transmission Plugged
I've never heard of a transmission getting plugged up. A transmission has dozens of passages that fluid flows through. It's extremely unlikely that ALL of them would get plugged up. Even getting just one passage plugged up is unlikely, since all the fluid passes through the filter first. Any particle big enough to plug up a passage wouldn't get past the filter. Also, if your transmission is generating particles that big, you have other problems to worry about.
It's possible the filter is plugged up. I would drop the pan and change the filter. This is good maintenance that should be done periodically even if you're not having transmission problems.
1happycamper
1999 to 2016 Super Duty
04-12-2018 08:44 AM
KMAPRO
06-07-2017 05:36 AM
RoyalFord
28
03-23-2005 04:33 PM
