7.3 psd 99 blow by question!
Hey all. Hope everyone is doing good! 99 psd 20000k 7.3
First off my truck has the ccv delete mod done.... The hose leaves the ccv and runs right under the engine....
Do the same rules apply to the ccv hose blow out - that apply to oil filler cap test?
IV noticed that every now and then when conditions are right - when I come to a stop I will see smoke come up by the fender - not a lot but noticeable.
I was looking at it tonight and it seems normal but idk.
I can feel a slight breeze from the end of the hose - if I plug the hose it doesn't try to blow out or anything.
Here is a video - this is right after getting off of the highway for 30 miles.YouTube
7.3 blow by:
Do I start making preparations to get a new engine?
or is this normal.....
Truck has plenty of power or relatively close to proper power......
One thing iv noticed is - if below 65 mph with less then 2000rpms it doesn't wanna accelerate up hill.... it has absolutely no problem keep its speed up hill - just doesn't wanna always accl! Sometimes it will but not always.
If above 2k it does a lot better.
If not trailer it does a lot better.
What does everyone think? Thanks.
7.3 blow by:
Next chance you get can you do the test at the oil cap by flipping it over ans see if it blows it off? I think this way is the current baseline everyone goes by. Actually, I believe, and someone correct me if I'm wrong, but the blow-by oil cap test should be done with the ccv plugged but not everyone does it.
If you don't feel pressure when you plugged it you should be good.
So oil cap test seems good huh?
As far as the acceleration issue, I would look into fuel pressure and monitor some of the trucks vitals while this issue is happening. A scanner or Torque app with a Bluetooth adapter will allow you to monitor Hpop pressure and duty cycle. This will help you narrow down the issue.
Don't know why but I've seen a few of the 99's have more blow by then the later models. At least from what I've seen on line and in person. They mitt of changed something in the later models I don't know, your cap test looks good but that dose seem like a lot of blow by off the bottom.
thanks for the info!
So I'll get on that.
I do know the truck has a new hhop on it and I newer updated turbo. The truck doesn't ever use any oil - at least none in 3k so far.
My other psd had this issue as well. It only wanted to maintain speed and not accl when climbing with a load.
Something weird iv noticed - the truck has a 6 speed in it.
my e brake is missed up so I have to park it in gear...... iv notice when I am on a pretty good hill [not huge but noticeable drop to it] if I have a trailer on me [ loaded or unloaded. It will try to creep away - slowly. Doesn't always do it..... [ it's a 250 super duty] so it's a Lil heavier... doesn't always do it and never does it with just the truck and no trailer.... doesn't take of - just slowly rolls. I mean slowly! I probably have 700 or so pounds of tools and such in the bed as well. Anyone ever experienced this? Thanks.
IV been looking at getting torque pro and ScanTool.net LLC - OBDLink MX Bluetooth Scan Tool | OBD Adapter - ScanTool.net
What is happening with your manual trans is that you are relying on the compression in the engine to hold your truck in place. There is and will always be some compression leak down, thus permitting your truck to creep. As it creeps it builds compression in another cylinder and slows or stops it...until it leaks down and the cycle begins all over. I would recommend you parking with tires turned against a curb if possible or use a wheel chock. You will undoubtedly have to move the truck off of the chock before you can pick it up off the ground after the truck creeps up against it.
Do you think I need to start worrying about a rebuild or what? IV got 200k I really need to make it to 3 or 4k.
What is a good ball park guess for cost to rebuild?
Thanks bud
Did a video with the ccv plugged and the filler cap- If I stuck my finger in the whole I could fill the breeze but it didn't even try to blow my finger out - no pressure at all.
Here is a new video. Watch "Plugged ccv blow by 7.3" on YouTube
Plugged ccv blow by 7.3:
The blow by in the video isn't anything to worry about. On another note. you talk about the smoke coming up from the truck while idling, my personal opinion is the crank case vent mod is the most useless/unnecessary thing you can do to any truck. I put new boots on several years ago and my IC pipes are still clean with no seepage. There isn't enough oil going into the intercooler system to hurt a thing. Not to mention the smoke that comes up while sitting at a light or while talking to someone. JMHO though...
. You wont know without a compression test. I've budgeted 4.5k for the engine overhaul, and another 2k for the transmission. Still cheaper than a new truck.
