360? 390?
360? 390?
let me start by saying I know ive seen this on here before.i need the measurement amounts to tell if its a 360 or 390. specifically when at bdc and a dowel is inserted and measured to the valve cover lip.
the problem is my internet connection is messed up right now and none of my search features work....half of my sites I cant get on either, no Bing search, no Yahoo search.......but, I can come post on here and ask. im sorry about that guys
dropping a dowel into a cylinder is one way: 360 = 3 1/2" stroke 390 = slightly more than 3 3/4" 3.784 if I remember right.
Another method would be to see the crank or at least the rear crank flange.
If you can see the casting number on the crank, that would tell you.
Or, if you can see the rear crank flange where it attaches to a flex plater or flywheel, The 360 has a larger half circle cut out on an edge of the flange, the 390 has a smaller square notch.
nobull4x4
12-07-2004 03:48 PM
Annihilator
10-15-2004 02:46 PM
blue66f100
06-08-2002 06:52 PM
