doing injector o rings
hey guys, i'm in the process of removing my injectors to do the o rings, i feel that i have a good grasp on the proper method of purging oil/fuel out as to not hydro lock, but my question is, most write ups i see say to jump the starter relay well the vc's are still unplugged with the glow plugs out, i dont see why i would jump the relay if i can simply turn my key sitting in my seat, correct..? any advice on the process is welcome! thanks guys. cant wait for beers after this.. oh and im also putting all new glow plugs in and going after my fuel pump today too, ive done both before.. not a huge fan of the fuel pump but i hope it solves my stumble at higher rpms if i get on the throttle, i will post my outcome!
Solid Point guys!! I'll fire her up and get some runs in before I go after the pump.. I Think its the original pump at 185k so I may just do it to do it..or keep it in the truck with my 1-1/4 wrench till it pukes out...haha. I'm not a huge fan of side of the road work but I will hold off till after my orings and its fired so I know what fixed my stumble!! Thanks guys
Well she runs again...took my sweet a** time as to not screw up.. Cleaned my injectors real well then lubed them all up with fresh oil and lubed the new o rings before install all in running pretty good, only got about a 10 min drive in so far and most the white/blue smoke has about cleared up already, I'll get some longer harder drives on it tomorrow and check back in! Thanks guys!! Just cracked my first celebration beer!!haha
R1racer
04-05-2017 08:47 AM
Shawn MacAnanny
22
10-30-2016 04:25 PM
fordguy_460
08-18-2009 04:28 PM
