Seized 7.3?
My 90 quit me on day, and the fuel heater had shorted out and melted the fuseable link. It had the same crappy type fuel heater as the strokes do. Your 93 probably has a fuse for the fuel heater in the under hood fuse box, as Ford started using the under hood box in the 92 model year. With the key in the run position you should have juice to the fuel pump selinoid.
The easiest way to see if the engine is seized is to put a socket on the bolt that holds the harmonic balancer on the crank, and try to turn the engine over with a breaker bar, with the truck in park if an auto, nutral if a manual tranny.If you can rotate the engine one full rotation the engine is not seized.
You're suggesting a fuse blew and that's what killed it? I hate to say this but I've never been in the fuse box.. Interesting I'll have to check.
Thanks again
Okay well I got the batteries back in off the trickle charger and tried starting it. Mind you this was without the alternator in, I don't know if that makes a difference. But when I turned the key it tried to start and then made some loud clicking noises. Starter?
Still haven't had a chance to check fuses and such. I'm super busy.
Thanks for everyones patience and help
Have you taken five minutes to put a SOCKET and BREAKER BAR on the crankshaft pulley bolt, to see if the engine will turn?
If the batteries are fully charged, it shouldn't matter if the alternator is not present when trying to start the engine. Just don't leave it running if you do manage to get it started that way. Without the belt, you have no working water pump.
#28
IT STARTED. I can't believe it but it did. Here's what went down:
I started the night by changing the oil and filter because it was about due. It was rather low on oil but not out. The oil was rather black and smelled like burnt..something. Anyway, I then put a breaker bar on the crank shaft and turned it 360 degrees (with some difficulty) Which prompted me to try and start it again. I got in and turned the key and the batteries barely had enough juice to power the lights, let alone turn the starter.
I though this was weird considering I only tried to start it once since taking the batteries off the charger.
I decided to jump it and when I did so it started. I only let it run for about 2 seconds as the belt and alternator were out and I didn't want to hurt anything. It ran a little rough and smoked some (I'm not sure where the smoke came from as it's dark). The running rough may be due to the fact that the truck has been sitting in winter weather for about a week.
Anyway that's my miracle story. I thought for sure it was seized when I drained the oil and saw it only had about 5 qts. But apparently not yet?
Thanks for everyone's input, any advice on the smoke and next steps to check the cause of death/lack of battery power are appreciated.
#30
