Buzzing between 1500-2000 RPM
Old 01-29-2015, 10:34 AM
3Mfarris54's Avatar
3Mfarris54
3Mfarris54 is offline
So I have searched and searched for a thread with my same symptoms with no luck.
Truck has a funny buzzing/vibrating sound that kicks in around 1500 rpm and gets the loudest at 2000 rpm. It almost sounds like a hydraulic whine. Above 2000 rpm it drones out due to the straight pipe exhaust. I have ran the truck up to 2000 rpm in park and the sound is still there, so I assume its not transmission/ drive train related. I cant pinpoint the location but from in the cab it sounds like its dead center of the engine compartment.
Anybody ever had anything similar? Maybe turbo related?? Thanks in advance.
Old 01-29-2015, 11:23 AM
1994F2507.3L's Avatar
1994F2507.3L
1994F2507.3L is offline
check my thread "electrical noise under dash" see if you think your situation is similar.
I think it's still on the first page here
Old 01-29-2015, 02:08 PM
madpogue's Avatar
madpogue
madpogue is offline
Does "straight pipe exhaust" include an aftermarket downpipe? Perhaps it's hitting/rubbing the firewall.....
Old 01-29-2015, 02:13 PM
3Mfarris54's Avatar
3Mfarris54
I looked at the thread, the only thing is my brake light isn't flashing.
As far as the downpipe, Ive been running that exhaust for a while now, thought I gave the pipe enough room when we put it in, but its worth checking out..
Thanks for the quick responses!!
Old 01-29-2015, 04:37 PM
1994F2507.3L
well my brake light didn't really start coming on until the end, probably the last 5-10 miles right before the pump crapped out... might be worth checking out to.... other thing could be up pipe leaking, I haven't heard it described that way but if the leak isn't very big i suppose it could make a different sound than if say half the doughnut was blown out or vice versa ya know.... just a thought.
Old 01-29-2015, 06:32 PM
3Mfarris54's Avatar
3Mfarris54
I agree. My first thought was the turbo, maybe the bearings getting old or the EBPV sticking
Old 01-29-2015, 10:30 PM
williameub's Avatar
williameub
williameub is offline
There was a TSB issued for moaning or buzzing at 1500-2000 RPM and it called for replacements of the motor mounts. I say this but only from memory. I could very well be wrong. I'll try to pull it up tomorrow.
Old 01-29-2015, 10:38 PM
williameub's Avatar
williameub
Old 01-31-2015, 07:27 AM
ReBilld's Avatar
ReBilld
ReBilld is offline
Also check the intake boot where it hooks to the turbo. Make sure it doesn't have any tears or holes in it.
Old 02-02-2015, 06:13 PM
3Mfarris54's Avatar
3Mfarris54
So I found the culprit. The edge of the downpipe clamp was just barely touching the transmission housing. But it was almost impossible to see without getting under the truck and having it ran up to 2k RPM and watching it buzz against the housing. A few crowbar adjustments later, no more buzz!
Thanks to everyone who posted replies
Old 02-02-2015, 07:37 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Cool! Things like that sure can drive you nuts can't they! Glad that's all it was.
bigdmizer
Modular V10 (6.8l)
41
06-29-2020 10:13 AM
mazdaprotege4
09-13-2014 11:47 AM
trevstaff
12-09-2011 12:58 PM
leviticus
04-05-2009 02:53 PM
true4.2
3.8 & 4.2L V6
01-08-2004 04:13 PM
Quick Reply: Buzzing between 1500-2000 RPM
