changing spark plugs on 97 F150 4.6L - Ford Truck Enthusiasts Forums
Old 07-21-2003, 11:26 PM
sjenkins sjenkins is offline
sjenkins is starting off with a positive reputation.
For all you guys out there with the 4.6, how hard are the spark plugs to change? Is it worth doing yourself or are the hours of cursing worth taking it to a mechanic.
Thanks
SJ
Old 07-22-2003, 04:19 PM
fordman19762003's Avatar
fordman19762003 fordman19762003 is offline
fordman19762003 has a very good reputation on FTE.fordman19762003 has a very good reputation on FTE.fordman19762003 has a very good reputation on FTE.
I took mine to a mechanic after seeing the mess I had to go through to get the plugs out. He said the front ones weren't too bad but the rear ones were a nightmare, I guess he had to remove the plenum and move some other stuff out of the way to get them all out. If you have alot of patience I would say give it a try and save yourself some money.
Old 07-22-2003, 07:02 PM
byo71 byo71 is offline
byo71 is starting off with a positive reputation.
i helped my buddy with his (or rather, did it for him). its not bad if you have a few different sized extentions and a universal joint.
Old 07-22-2003, 09:39 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Hi SJ and welcome to FTE
At the top of the forum is a thread on replacing your plugs. There are instructions and lots of tips from the other guys on here that have done the job.
Be prepared to have a few hours to do it the first time you try.
They are a pain but not as bad as they look.
Get a quote on the job if you take it to get it done. Last week I got paid 1.1 hours to replace plugs on a truck like yours. Flat rate has come down. It used to be 3 hours I think.
Old 07-23-2003, 08:19 PM
03f150man 03f150man is offline
03f150man is starting off with a positive reputation.
i replaced my wires as i replaced the plugs on my 97 4.6. so i dont know how long it would take to just replace the plugs but plugs arent too difficult except for the #4 (firewall passenger side). The plug wire connector spacers are a pain and take some time. Racerguy did the plugs in an hour, it would probably take me 3 hours but i like to go slow and savor the experience. if not in the tips above, remove the tires and lower the truck near as you can to the ground. this really helps if you an amateur and less than 6 foot.
Old 07-24-2003, 01:13 PM
peterbilt peterbilt is offline
peterbilt is starting off with a positive reputation.
Racerguy,
You deserve 3 hours rate to change plugs. Even if your use to it, 1 hour seems like you have to rush things.
Pete
Old 07-24-2003, 05:47 PM
Racerguy's Avatar
Once you've done a few sets 45 mins is about all it takes....as long as you dont run into any snags.
How to change spark plugs on a 2000 F-150 4.6L Fulford 1997 - 2003 F150 1 02-01-2013 07:51 PM
Best Plugs & Wires for 2006 4.6? someguyarerude Explorer, Sport Trac, Mountaineer & Aviator 9 02-06-2012 08:00 PM
do the 4.6's have the same issues with the spark plugs? reamer 2004 - 2008 F150 2 05-04-2011 10:20 AM
4.6L and Spark Plug Replacement johntucker09 2004 - 2008 F150 8 02-08-2007 03:37 PM
Spark Plug Torque scslee29680 Expedition & Navigator 6 03-05-2005 05:53 PM
Tags
1999, 2003, 2005, 46, 46l, 97, changing, changingsparkplugs, f150, ford, plug, plugs, removing, spark, spcs, tips
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
