Throwing an IDM Code...ugh...
#31
#34
So, here is the Wire Schematic for the 42 pin connector. Seems as though #21 is supplying the reference voltage for the CPS, MAP, EBP sensor & ICP sensor.
#36
#37
OHM'd the driver side. I was going to the big hole, not the small one under it. Everything on the driver's side ohm'd to 3.3 to 3.8. With those readings if it was a bad solenoid would I get a higher reading or is that just telling me the wires are good?
Having a hard time getting the solder to stick to the wires to patch in a new piece. going to use a solder gun after dinner instead of the butane one I've been using.
Think I'm going to call it a night once that wire is fixed and pick back up tomorrow.
Instead of the mess of pulling the injectors, I think I might just swap #2 and #4 solenoids. That should move the problem/codes shouldn't it?
#38
Prior to moving the Solenoid, compare both solenoids to determine if they're approximately at the solenoid connections.
#39
#40
#41
Rich, I think he is referring to a butane soldering iron. In the cold, they don't put out a lot of heat. You are right to caution about a soldering gun. That is way too hot for itty bitty wires. If the wind is blowing on the wiring, a cardboard shield and an electric iron sized as Rich says 35 - 45 watts is plenty. Or be real quick with the trigger on that soldering gun!
#42
Not that I think this is the issue, I'm going to throw the IC pipe in real quick and start it up to see if that was the problem. I know deep down inside it isn't but a guy can hope....
#43
Just getting back on this...
Put in new valve cover gasket and new UVCH. Moved injector solenoid from #4 to #2.
Cleared all codes with AE, ran buzz test. Code did not move with injector solenoid. Still getting a code for P1274. Injector #4 high to low side open.
IDM?
PCM? (I know this probably isn't the one but who knows at this point)
I'm starting to scatch my head on this one....help.....
IDM?
#44
#45
