Another Cummins Swap... - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Log In
Old 01-29-2015, 05:44 AM
xringonly xringonly is offline
xringonly is starting off with a positive reputation.
And by "another" I mean on this site and in the truck. It currently has a 4bt, ZF 5spd and 1356 xcase that was installed 8 years ago. Its been a great little engine, great mileage, always dependable, light local towing locally no problem. However, got some towing coming up in the mountains for vacation and hunting so gonna shoehorn a 6bt and 6spd between the framerails. I already have the engine sourced from a school bus, 1996 190 hp CPL 1551. Still trying to find the trans, Fuller, Ford, Dodge, whichever I find first, (affordable, I dont have a money tree), is going in. Gonna be a slow moving thread for awhile since Im still gathering parts and this is my DD so I will need all my parts in a pile on hand before starting. The plan is to be complete by the end of April. We all know what happens to plans tho. Thankfully there are some EXCELLENT builds on here that aren't copyrighted so I can copy and steal to save some time hopefully.
__________________
1979 F250 CC 4x4, working on 6BT/ NV5600 install,Griffin radiator & aftercooler, sterling rear w/ARB, '86 1 ton rear springs, '06 Sierra front & rear seats, VintageAir, D60 front waiting for some lovin. Build thread: http://www.ford-trucks.com/forums/13...mins-swap.html
Old 01-29-2015, 05:51 AM
On the subject of parts, Ive been doing searching and such for "Cummins" brand parts and its a jungle out there. I live a 100 miles from any major city so I can't run down the street to local dealer. Any suggestions for mail order "Cummins" brand parts? I will overhauling my engine first since its been stored for about two years.
Thanks, Carl
__________________
Old 01-29-2015, 07:02 AM
co425's Avatar
co425 co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
Prices are slightly higher then an actual cummins dealer but puredieselpower.com has been a reliable source for me in the past.
__________________
1974 F250 4X4
Cummins 12v, NV4500 , np205, Dana 60 Front, GM 14 bolt rear.
Cummins swap/truck upgrade thread
http://m.ford-trucks.com/forums/show....php?t=1181279
LIBERALISM IS PESTILENCE!!!
Old 02-01-2015, 08:46 PM
Thanks co425, I will give them a look.
__________________
Old 02-01-2015, 09:24 PM
Im starting to see why these builds take so long...life gets in the way. The list would be too long to type here of the things that come up to prevent me from having fun with my engine/truck. Oh well. Finally got to do a little today. Disassembled my engine, all looked well, great actually. If I had X-ray vision I would have just stuck it in the truck and run it another 160k. I knew it ran great when I pulled it but its been stored for 2 yrs and I was worried about the rings not being exercised and collapsing. All rings were good, piston squirts are good, There was some very minor wear on the top of three rod bearings, and barely detectable wear on the front cam bearing. All cam journals and lobes are pristine, lifter bases without a mark. All rod and main journals look new. Front and rear crank seal areas are good. The crank is still laying in the block so when I get it out, hopefully tomorrow, I can inspect the sprayers. Gotta get some parts ordered!
__________________
Old 02-01-2015, 09:54 PM
Click the image to open in full size.
Mostly stripped
Nice shot of the crank, and my dads arm.
Beautiful rod journal
Misc parts on the second hand shelves just purchased Friday
Waitng for a little loving...
__________________
Old 02-02-2015, 08:26 AM
1972RedNeck's Avatar
1972RedNeck 1972RedNeck is offline
1972RedNeck is gaining momentum as a positive member of FTE.
If you're going to be doing a lot of towing but still want highway gears, you should look into the 6+1 spicer overdrive tranny and run 3.54's. Nice low gears in the tranny, close spacing, and still have a nice overdrive - worth a thought.
What are you doing with the 4BT, tranny, and t-case? I might be interested...
__________________
1966 F250 4X4 416 Clark 280V
1990 F350 4X4 4BTA E4OD
Quote:
Originally Posted by HIO Silver View Post
Why polish a turd?
Based on everything I've here in Fte, websites, and articles, a 12-valve Cummins is the no-brainer choice.
Quote:
Originally Posted by F357 View Post
Let's be honest, people just don't swap powerstrokes. There is a reason for this.
Old 02-02-2015, 11:54 AM
somethingclever's Avatar
somethingclever somethingclever is online now
somethingclever is gaining momentum as a positive member of FTE.somethingclever is gaining momentum as a positive member of FTE.
Did you make that engine stand using a D60 rear axle with a sprocket/gear welded to it to be able to rotate it utilizing the hand crank?
If so....freakin awesome.
So.....with a 4bt and zf5 in a dentside CC 4x4 truck - what was your avg fuel economy, best highway fuel economy, and just to be clear, you are correcting for speedo/odo error....?
GOt any pics of the truck?
__________________
1978 F250 4x4 Super Cab - 400, C6, NP205, 3.55, Dump and Plow - Work Horse
1979 F250 4x4 Crew Cab - 466, T18, NP205, 4.88, 9" lift, 40" toyo's - FAMILY WAGON
Old 02-02-2015, 03:53 PM
oddfordjunkie oddfordjunkie is offline
oddfordjunkie is gaining momentum as a positive member of FTE.
Would love more information and photos of the trucks current setup with the 4BT.
__________________
1978 F-250 CCSB 460-ZF5-D60
http://www.ford-trucks.com/forums/13...ld-thread.html
1961 Econoline 5 window pickup 144 I6
1985 E350 14" Box Van 6.9 IDI
1968 Dodge A108 Van /6
Old 02-02-2015, 05:21 PM
I would love to have a Spicer 6+1 or fuller fso6406/8406. Theres just not an affordable source around here that I can find. I have feelers plugged into fleabay but the same story there.
Complete 4bt/trans/xcase will be sold when the swap is complete, my nephew has been after me for two years so he gets first choice. If he doesn't want anymore then it will be open to the public, there are several individuals local that are jumping up n down for it, (known good running setup). I will keep all informed.
__________________
Old 02-02-2015, 05:36 PM
Wow, you came by your name honestly. Yes, that is an engine stand fabricated around a D60 hub/spindle. I wasn't going to trust my engine to some POS china made junk so I made one to handle all I could throw at it. Worm gear setup is from HF 2k hand winch, I need to do a little more shimming to take slack out of it but it works good. Very stable. I may do a build thread on it if there is enough interest, in between engine stuff.
Avg MPG around 24. Hwy around 26. Best was 27.5. This was couple years ago, my odometer slips now so impossible to figure. New injectors last spring, calendar days between fillips is longer now so prob doing a little better. I do drive for economy so the average JOE probably get a couple or so less MPG.
I think I have a pic or two somewhere, will post later. Its not pretty right now, awful purple paint. One more child out of school then I can complete body/paint.
__________________
Old 02-04-2015, 08:15 PM
Thanks again co425 for the headsup about puredieselpower.com. Very helpful folks, ordered a bunch of goodies to get my engine up and running.
__________________
Old 02-04-2015, 08:56 PM
co425's Avatar
Quote:
No problem. X2 on nice engine stand. Need some more pics of that for sure.
__________________
1974 F250 4X4
Old 02-04-2015, 09:39 PM
That is incredible fuel mileage.
__________________
Old 02-04-2015, 10:03 PM
blue04.5's Avatar
blue04.5 blue04.5 is offline
blue04.5 is gaining momentum as a positive member of FTE.
xringonly- I'm signing on to follow along.
genosgrage.com is another good source for parts. Good luck on your build, hope it goes smoothly for you.
__________________
74 F100 dropped 2wd, roller 347
64-73 JBA mustang headers - 6612S
Trickflow heads, super victor intake, comp cams
Quick Fuel carb
T5 transmission
All custom fit.
Similar Threads
1990 Ford F700 Bucket Truck C-Jones Lawn & Tree Large Truck 11 07-04-2015 10:41 PM
1985 ford f250 motor swap debate Jrod67 Engine Swaps 11 11-18-2014 07:27 PM
1955 Ford F100, F350, Big Job, Original Suspension Modifications & Setups Johnnynobody 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 11-17-2014 04:25 PM
460 to Allison, Clark, Fuller rje Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 8 10-15-2013 02:15 PM
Lengthen Frame or Buy One? xmontex4 1987 - 1996 F150 & Larger F-Series Trucks 28 10-10-2013 04:47 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
