What is the max size of pics to upload? I can't load pics anymore and can't figure out why. I ve seen the max size before but can't find it now.
Thanks, Carl
Thanks, Carl
Your better off creating a photobucket.com account. Upload your pics then copy and paste the IMG code. Paste that code into your post. This way you don't need to re size your pictures.
I have a "60" but its a later model and has wider spring perches. When I install will probably do coil springs/4 link. Not enough time to do engine and diff so a little reinforcing in the meantime. Pardon the crooked bumper, gonna build one soon as I get my press converted to break sheet metal.
Roof rot, all the way across under the windshield gasket. Very time consuming when I have poor body skills. Fellers, if you haven't inspected this area of your truck I highly recommend you do so before it gets to this point.
