302 swap?
^^^^^^That's a totally different question.
Your first post was simply swapping engines that are not of the same engine family... no luck there.
More info needed.... 2WD? 4WD? What trans do you have now? Type? Model Number? The more info you can provide usually results in better responses.
Actually the 351c and 302 have the same bolt pattern for the bell housing. Now whether you actually have a 351c which was never offered in a Ford truck (not counting a Ranchero)is a different matter. There have been lots of 351m's that magically turned into 351c's because owners didnt want to tell their buddies thats what they had.
Sorry Paul I started this about 30 minutes ago and got called away. Didnt see your post til after I posted.
Last edited by gatorfor88; 01-28-2015 at 07:42 PM. Reason: I was pre-empted by Paul, Hell I was pre-empted by 85e150 too
They are cousins, but the 351c is more like a little cousin with a small block pattern while the 351m/400 are older cousins with a big block pattern.(Even though I have been corrected on here before by someone who says "small block and big block" is a Chevrolet term and was never designated that by Ford. I have heard it used my whole adult life so I choose to use it also)
My apologies Erik.
351C = 1970/74 misc Ford/Merc Passenger Cars & Ford Ranchero's only.
351M = Misc 1975/79 Ford/Merc Passenger Cars - 1977/79 F100/350 - 1978/82 Bronco - 1980/82 F150/350.
