LOOSES POWER GOING DOWN THE ROAD AND WAIT TO START LIGHT COMES ON, HELP!!!
Old 02-04-2015, 12:15 PM
fordpride's Avatar
fordpride
fordpride is offline
Cps will cause a no start but it won't cause the wts light to come on.
Old 02-04-2015, 02:44 PM
Tyethornton's Avatar
Tyethornton
Tyethornton is offline
what about if the CPS was no working completely? or someone even mentioned the IPR may be loose or bad and cause it to do that, is this true?
Old 02-05-2015, 07:00 AM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
The fact that the WTS light is coming on means that the PCM is losing power and rebooting just like it would if you turned the key off and back on. The CPS won't cause that. I bad or loose fitting chip, on the other hand CAN cause the PCM to reboot.
Replace the CPS if you want to, but I don't think that's going to solve your issue. If this truck is chipped, then first thing you need to do is pull that chip out of it and see if it still has this issue.
Old 02-05-2015, 08:02 AM
Tyethornton
Update: I took the ECM out and looked at my chip, looked a little loose but not enough to really tell though. But I blew it out and plugged it back in and it started up. Also I noticed my ignition is loose when I turn the key, I can shake it pretty good. Someone mentioned that a loose ignition can make it do it as well.
Old 02-05-2015, 08:07 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
If it were me I would run it without the chip just to see if the is the problem. If it fixes it then bobs your uncle. If not then you know that's not the problem.
Old 02-05-2015, 08:28 AM
madpogue's Avatar
madpogue
madpogue is offline
Yeah, maybe the THIRD time he's told, he'll actually try it....
Old 02-05-2015, 08:29 AM
MOOSE_MACHINE
Ohhh, I'm not telling him to do anything. I'm just telling him what I would do.
imjwm
18
05-07-2014 08:44 AM
heartnurse73
16
06-21-2012 02:50 PM
240spoke
55
02-25-2010 07:26 AM
Kentuckyrocks
03-04-2008 12:31 PM
jaco96
02-13-2008 03:37 PM
Quick Reply: LOOSES POWER GOING DOWN THE ROAD AND WAIT TO START LIGHT COMES ON, HELP!!!
