Sct livewire reviews
Here is what I see listed on the SCT Site for PIDs. I am considering the SCT Livewire as well. It has about everything that I want to measure while driving. Anything else I need to measure I can do with my AE while performing diagnosis. You can also add an analog input (not more than 5 volts) that can monitor fuel pressure.
Ford 7.3L and 6.0L PID's
ACCEL PEDAL POSITION
AIR FLOW #/MIN
BAROMETRIC PRESSURE IN HG
BATTERY VOLTAGE
COMMANDED GEAR
COOLANT TEMP
ENGINE OIL TEMP F
INJECTION CONTROL PRESSURE
INJECTOR PULSE WIDTH
INTAKE AIR TEMP
LOAD
TURBO BOOST
MAP
RPM
TORQUE CONVERTER CLUTCH DUTY CYCLE
TRANS TEMP
VEHICLE SPEED
VGT DUTY CYCLE
FICM_IGNITION
FICM_LOGIC_POWER
FICM_MAIN_INTERNAL_INJECTOR_PWR
AIR FLOW #/MIN
BATTERY VOLTAGE
COMMANDED GEAR
COOLANT TEMP
ENGINE OIL TEMP F
INTAKE AIR TEMP
LOAD
TURBO BOOST
MAP
RPM
TRANS TEMP
VEHICLE SPEED
VGT DUTY CYCLE
FICM_IGNITION
FICM_LOGIC_POWER
Woody79
11-09-2013 12:26 PM
