HIO Silver's '73 F100 SB 4x4 "The War Machine" Mod/Upgrade Thread
#47
#49
Buddy Dwight says he had an ICM on his 78 f350 cube, 7.3 diesel, it puked in november 97 for the fist time that he knew of and he ran truck since new but had Loomis wet serve looking after truck. Hes the guy who got me my Icm, his icm was mounted on the intake manifold and puked on it and his bellhousing. That is a dirty high vibration and high temp area, if the one that puked was original it would have had 180, miles of in town use. Forgot, when mine puked I also replaced a piece of electrical on my distributor, dont know what it was called but it bolted on and had 2 wires coming off it. You know enough about electrical that its either resistance on the system its feeding or to much amperage/ power coming in. Hope your cure works.
#51
#52
Arrightee.. the LBB is on the road and it's time to get back to the WM in earnest.
Main tray
Auxiliary tray and under-fender bracket
I think this is a '79 auxiliary battery harness.
Yuck.
To do:
- Fabricate a tray for the ICM and wire in a computer cooling fan.
- Figure out where to put the switches.. I'm thinking on the dash bezel above the headlight switch were an AC vent would be - fogs, driving, inner roof, outer roof, DRL kill switch, and a spare.
- Install a couple of circuit breakers.
- De-rusted the battery trays, rebuilt them, refinished with POR + topcoat, and installed.
- Made up new battery cables
- Attached extra grounds (still gotta weld on some studs to the frame).
- Installed the GM train horns.
- Reinstalled the engine bay wiring.
- Ohmed out the dual battery harness and installed it with the continuous duty solenoid. Needed to drill a one-inch hole in the stock location on the firewall but couldn't find the correct hole saw arbor. Dang it! I did identify where it should go so that necessitated removing the instrument bezel and cluster....... Removed the filthy and dusty cluster and figured the haze would just buff out. NOT! It's yellowed with age and scratched up. I'll skip it for now since it is relatively easy to replace later.
Main tray
Yuck.
To do:
#54
#55
Go with four colors... it's more legit than the typical three. Btw, if you're right handed, resist the urge to do right-handed arcs. Switch hands to balance it out.
#57
