rattle tattle tattle doors driving me crazy adjustment
im my 78 when i go offroading, the drivers and pass front doors rattle tattle tattle me to crazyville. ive adjusted the strikers as far is as they will go still the door when its latched will move in and out 1/4 inch at the striker!
what is the trick with these doors?
Vettex2 you link takes us to an opening page for McMaster---any particular parts you use there for this?
Skip what you're probably dealing with might be one of two things: worn or aged parts that need to be replaced OR too much body flex never anticipated by Ford when that body was designed.
Door and body seals in the door openings as well as worn latches or strikers probably are all contributing to those rattles. If those parts are original to the van they're 36 y/o-----kinda past the point they'd be expected to last.
If that movement you describe is when the van is sitting still----age has taken its toll my friend.
Do the pex mod if your doors strikers no longer have bushing, it works great!
i will try to improve it more, for now this is a huge improvement!
Sounds like he found the real issue though.
moosey78
01-02-2014 05:40 PM
