Queston about 48-50 rear fender top shape
I am in the process of priming and blocking my original rear fenders. It turns out that both fenders have a barely perceptible "valley" on the top of the fenders just outboard of the mounting flange. I started to fill and block this area on one fender and then I noted the same shape on the other fender. Has anyone else noted this? It became apparent when I fogged a guide coat on top of the primer and started to block that area. I suspect that it would show as a slight valley in finish paint if you looked along the top of the fender from behind the fender? Anyone?
That is what I expected. I need to decide weather to fill the slight valley on both or leave both with the slight valley. The way that I am blocking the fenders is to mount the fender to a flat 3/4" plywood backing shaped to the mounting flange and then I have the plywood firmly bolted to one of my engine stands. I do have the plywood held straight front to rear by screwing it to a straight length of 2 x 4 on edge. This setup allows rotating the fender but holds it firm for blocking on the top, front and rear surfaces. I block the "face" of the fender on a flat table.
Stampings can vary depending on how worn the dies were at the time or from plant to plant. These were never designed to the level of a Lexus. The area you're describing will be underneath the top bedrail overhang, and will never be seen. Don't lose too much sleep over it. This is coming from Mr. Critical.
Thank you all for your responses. I suspect as Wayne suggests the dies could have been a bit worn. Although the slight depression may not be common, it seems like I am not the only example. To me the fact that it is the same on both fenders is significant. I am going to ponder it a bit more. I am leaning toward skim coating both in that area. I do share the concern expressed by Ross, however, the skim does not go to the flange edge.
oscajo
12-09-2013 09:48 AM
Rokcrln
100
03-10-2013 06:32 AM
