Finally joining the club--going to tear into the truck
A little piece of gorilla tape or duct tape will hold the torx bit in. I had to do this when I removed the pass side oil rail. I used a ground down torx bit inside a 1/4" socket on a 1/4" breaker bar. Just make sure there is no oil on the bit or the tape won't stick, you don't want the bit coming out and falling into the engine.
2006 F350 4X4
I actually haven't. All appeared fresh when I bought it so it hasn't been on the radar--but I suppose it would be advisable
On the brakes--the next change I'll be rebuilding the calipers but that is going to be another 100k miles hopefully so I should probably do thd fluid this time around then.
2006 F350 4X4
2006 F350 4X4
Well since I can't make it to SDS to do any work ( about the only ones I would trust) I'll have to settle with getting the parts from them. Julie worked up the parts list for what I'm doing and quoted me dang near the same as what I could piece together from 3 different places ( cheaper actually-few other odds and ends that wouldn't be with the others). This is the delete, dp,standpipes, stc,all gaskets and hardware--even a list of tool sizes. I'm happy about that. Now to order and schedule some time off Thanks again SDS for getting the list to me quick.
2006 F350 4X4
2006 F350 4X4
Well been crunching the numbers an gonna try and add the 190 Dc alt and wire kit to my list. I really want to do it all at once but we will see may still have to split it up and do the alt later. One question for yall. Since I'll have everything off of the top of the motor should I pull the oil cooler and replace the screen? Not planning on changing it since it is in great shape. What are ya'lls thoughts on that?
2006 F350 4X4
2006 F350 4X4
Well been crunching the numbers an gonna try and add the 190 Dc alt and wire kit to my list. I really want to do it all at once but we will see may still have to split it up and do the alt later. One question for yall. Since I'lllb have everything off of the top of the motor should I pull the oil cooler and replace the screen? Not planning on changing it since it is in great shape. What are ya'lls thoughts on that?
2006 F350 4X4
2006 F350 4X4
Josh
I wouldn't either. That's a helluva lot of work unless you have a very valid reason. You can get more contamination than what you might already have if you're not careful.
2006 F350 4X4
2006 F350 4X4
#28
#29
Started ording parts today. Ordered fuel and oil filters, trans filter, new 08 trans pan and gasket, and an extea turbo mount kit (just to be safe)Will be ordering my main stuff around the 1st. Will pick up the y pipe core this weekend and get it sent out and start picking up all the fluids. With this weather I'll have tons of time to get everything in hand before I get to work. I usually dont work it that way but seems to be working out better that way. When I get started I'll start a new thread and have pics, part numbers and such so it'll be all in one place.
2006 F350 4X4
2006 F350 4X4
#30
