Battery light on
Old 01-27-2015, 09:06 AM
varminthunter243's Avatar
varminthunter243
varminthunter243 is offline
Battery light on
Battery light is on. Gets. Richter as rpm comes up, almost goes completely out at idle. Thoughts?
Old 01-27-2015, 09:07 AM
varminthunter243
Gets BRIGHTER as rpms come up. Stupid phone
Old 01-27-2015, 11:03 AM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
Get one of these and see what it says under various rpm conditions. This will help with possible causes and solutions.
Amazon.com: INNOVA 3721 Battery and Charging System Monitor: Automotive Amazon.com: INNOVA 3721 Battery and Charging System Monitor: Automotive
Old 01-27-2015, 12:37 PM
whitetmw's Avatar
whitetmw
whitetmw is offline
What year is your vehicle. This is important to know how to proceed. There were two changes in the indicator illumination systems for the battery lamp.
Old 02-06-2015, 09:03 AM
varminthunter243
03. The old alternator was charging but the regulator wasn't upping the output when the load increased. Threw a meter on it while it was running and added to the load little by little and watched battery voltage drop and the alternator output stayed constant. Changed the alternator and had them bench test the old one and sure enough it failed
Old 02-06-2015, 11:08 AM
whitetmw's Avatar
whitetmw
whitetmw is offline
Good deal! Glad it worked out for you!
* On 03 there is a resistor in the panel which is nor serviceable. There are after market shops that will repair it for you if that were your problem.
bjkidd2004
1997-2006 Expedition & Navigator
13
10-25-2007 08:59 AM
984x4F150
1997 - 2003 F150
09-20-2006 06:49 AM
dfru
07-25-2005 05:28 PM
bstopek
12-22-2004 01:39 PM
mcastleberg
Electrical Systems/Wiring
12-10-2003 10:58 PM
Quick Reply: Battery light on
