EBPV sound when closing
I recently hook my EBPV for the cold weather. yesterday when i came out to crank and let it warm a bit i noticed after about a min or so idle the speed would increase a bit and the EBPV would close.
After about 5 or so seconds it would start sounding like it was pulsing. I took a video of it. take a list ten and let me know if that is normal or wierd and why if you don't mind.
Warming up like that is normal. And yeah, hitting the brakes or the accelerator will open it back up.
The pulsing sounds like romping to me, but I've only experienced that in gear while backing up, not while my EBPV is closed at idle for warm up purposes.
Stewart
Stewart
The PO had no clue what it was. I don't think he used any diesel conditioner as i did not see any bottles in truck and it was not mentioned.
I will be doing a turbo rebuilt this summer and will do EBPV, pedistal etc at that time so i may find some buildup on valve.
My truck has never done that, but I have experienced little to no power on cold morning start ups a couple of times. No noise like that however. The couple of times that I have had to romps though it really ROMPS. Almost feels like one whole bank is dead for a couple seconds and then runs fine.
That was a GREAT idea posting the audio. Wish more would supply pictures and audio. What a help! Reps!
Unfortunately, I'm almost Deaf! What your explaining sounds normal.
How I characterize it is it's HI, LOW, HI, LOW, similar to romp but noticeable only in the Exhaust.
This was eliminated on the latest Flash. The ONLY reason it was eliminated was because of "customer concerns". The later tune holds the EBPV in one position rather than cycling. You may also see some faint white smoke on a very cold morning as it dumps fuel in its strategy between the event to maintain idle at about 1,000 RPM.
** This still occurs on the latest flash when the outside air temperature and oil temperature is below 30*F. You can ask around and I think you'll hear people say "Yes, that happens every now and then".
** If you have a Chip like a DP Tuner, with the high-idle/EBPV Tune it holds the EBPV Steady once installed and none of the strategies are employed when it is.
If this is what it is, and this sounds like the event your seeing, there is absolutely no problem. IH did not change their strategy because of this, only Ford.
at first it stay more constant like it more closed.. I plan on putting the EBPV on a switch on the dash for braking, along with TC lock up, so I will be able to control the valve and eliminate the pulsing..
should i have the software reflashed? I think somethink was done when the CPS recall was done but i was not owner then.
Any way to find out what has been done on truck. I hear the oasis report?? what is that.
thats good info on the tube and sensor.. I did clean the tube already but did not check the sensor. Sound like it might be easier to just replace the sensor with now 169K miles.
and to the oasis report.. if i go to ford dealership and they will do it?? any cost? what if my truck is over 10 yrs old. It goes back 10 yrs from today not from date of manf??
thanks for the replys..
The 10 year rule isn't hard and fast.
Stewart
