Problem - 1994 F150
Problem - 1994 F150
So, here we go. I am going to tell you what I have done and had done before I tell you what is wrong. I have a 1994 F150 4.9l 4WD.
I bought the truck for 2k (a steal for a Straight-6 with 202k I thought), but I was wrong. Nothing seemed wrong at the time, but I've had to do a lot of work.
I did and had to do the following: Changed front and back brakes
My first question is, where did 10 qrts of transmission fluid go in one week? It has been sitting for days since I had the trans pan gasket replaced and there's definitely no trans fluid on the ground.
Second, why is it stalling or almost stalling in reverse? I thought the trans filter fell off, but wouldn't it stall all the time and not intermittently?
I have not put any trans fluid in it yet to check if that is the issue. I wanted to leave it dry so that the shop could see if had no fluid in it (which will be tomorrow).
My second thought after the trans filter was the IAC valve, but the truck idles fine.
Anyone had any ideas why it is stalling? I have already dropped like 900 into the truck for the items listed above, so I don't want to throw parts at it to figure it out.
- Replaced front brake calipers
- Replaced thermostat
- Replaced thermostat housing
- Replaced PCV valve (including crankcase beather filter and air filter)
- Changed alternator and alternator harnesses
- Replaced serpentine belt
- Changed oil (previous owner put synthetic in it), oil filter and oil pressure sensor
- Replaced upper and lower ball joint
- Replaced transmission pan gasket.
My truck voltage goes down when shifting in reverse too, I heard it needs a new filter and transmission fluid but who has money for 14 quarts of that expensive stuff. I put it to the side for now. I think the IAC valve would affect the way it idles in park not shifting but I am no mechanic.
2. With the E4OD, low fluid = engine stall. That's why when your filter falls off it will try and stall then too. Because without the filter the trans can't draw enough fluid up from the pan, just like if the level was actually low.
3. That list of things you did to her really ain't that much. It's mostly basic maintenance and I'd say you got a pretty good deal if the body's in good shape!
4. Your low voltage condition happens when the engine is fixin' to stall because the RPM's go way down. At such a low RPM, the alternator can't provide enough output to charge the battery AND power the truck's electrical load, so you see the voltage drop down to whatever the battery is at.
1. Not sure where your fluid went. If it ain't on the ground then it probably either blew back all along the undercarriage or it was never there in the first place (didn't get it full after servicing the trans).
See #4 above, that's why you have low voltage.
As for the missing fluid, my brother-in-law was at the shop after they changed out the pan gasket and he swears he watched them put all 10 qrts I bought in the truck. But, I am with you all. It doesn't just evaporate! And, it isn't on the ground. So, I don't know what the hell is going on.
Either way, I am taking it back to the shop for them to take a look. I'm not putting any trans fluid in it so that they can see it is empty.
Thanks for the input!
NO! Don't drive it to the shop low on fluid. If the pump can't get enough fluid then you'll start losing line pressure which means the clutch packs/bands will start slipping. Pretty soon that will cook whatever fluid is left and you'll be looking at a rebuild.
Also, did you drain the converter when the trans was serviced? If so then 10 qts ain't enough. It's around 16 qts total to refill the converter and pan.
16 qts though? I was told from autozone 10 total
I don't mean to waste your time as it should be very hard to mistake were your putting the fluid but just a quick thought. have you checked the level with the engine off if the converter has never been replaced then most likely you might get a reading on the dip stick unless its really under filled.
Thanks again for your insight. Last question, I swear! I saw your response about not driving it, but how much damage could it have done off 10 qts instead of 16 qts over 3 days of driving it? It took about 3 days before I noticed anything wrong.
The truck now went back to shifting real hard in to reverse. It's not stalling, but this one has me stumped. I can't figure it out. All other gears shift and engage normally.
Sorry if the video quality is bad. If too bad, I will take it during the day tomorrow.
Ps, don't worry about the oil gauge. Faulty sensor.
<a href="http://youtu.be/jL2PLE3BBC0">Youtube Link </a>
