The parts wanted thread. - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 08-18-2015, 05:36 PM
Me_Rock Me_Rock is offline
Me_Rock is starting off with a positive reputation.
Wanted: #1 fuel injection pressure sensor
I cross threaded the injection pressure sensor on my '90 7.3. So far I've only found new ones for way too much money. Anyone have a spare?
  #62
Old 08-18-2015, 07:58 PM
BruteFord BruteFord is offline
BruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud of
Quote:
Injection Pressure Sensor? Never heard of it.
  #63
Old 08-18-2015, 09:53 PM
Quote:
It's the doohickey on top of the #1 injector.
  #64
Old 08-19-2015, 04:59 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
got a picture, i have no idea what you are talking about.
the only thing on top of the injectors are the return line caps which press on with o rings, and the high pressure lines which screw on.
  #65
Old 08-19-2015, 06:14 PM
sjwelds's Avatar
sjwelds sjwelds is offline
sjwelds is starting off with a positive reputation.
Thinking he means the timing adapter....Just a WAG
  #66
Old 08-20-2015, 12:19 AM
NAPA AUTO PARTS | PART DETAILS
This part. No idea why it's so expensive.
  #67
Old 08-20-2015, 12:28 AM
I got one kicking around somewhere, if I stumble across it and you still need it I'll find way to get it to ya.
  #68
Old 08-20-2015, 06:43 PM
i ain't rite
i have no idea what that is or what it is for, none of my engines ever had that on them.
  #69
Old 08-30-2015, 02:22 PM
fordman67's Avatar
fordman67 fordman67 is online now
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
Needing a. T-19 bell housing if anyone knows of a source by chance.
Any help much appreciated!
  #70
Old 08-31-2015, 02:32 PM
DarkOverCast DarkOverCast is offline
DarkOverCast is starting off with a positive reputation.
Yours cracked?
Mine did. Badddddd from the bottom through the clutch fork hold and up to the top. When i'd push the clutch it would just flex the bellhousing apart.
Couldn find a used on and its my daily so i took it to my good buddy at the local welding shop. He tig'd it back together front and back. 60 bucks later its holding strong. Been four months?
  #71
Old 09-01-2015, 12:22 AM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
A friend of mine wants to do a conversion on a GM- based motorhome. I need a 7.3 and C6 in decent shape, preferably a complete donor so I have everything in one shot but just an engine and trans will work too.
  #72
Old 09-02-2015, 07:46 AM
fordman67's Avatar
I was hoping to swap an idi into my 65 f600. I read that the t19 bell would work properly with my present trans. I however have investigated and there is no place for a pad to convert to a modern trans mount system. Never mind on the bell I am going to have to stay with the ft.
Thank you for your time.
Ford six, contact madmatador78 I think he might be able to help you out.
  #73
Old 09-02-2015, 06:27 PM
i ain't rite
<p>to put the IDI in the F600 you will need to find a diesel bellhousing for an international&nbsp; truck from the 80's.</p><p>or find a 4 speed bellhousing from&nbsp; a 80's idi truck and make a trans mount crossmamber</p>
  #74
Old 09-03-2015, 06:42 PM
Psychowolff1 Psychowolff1 is offline
Psychowolff1 is starting off with a positive reputation.
E350 Block side Motor mounts/brackets.
Hi all!
I am in need of a pair of Motor Brackets/mounts that bolt to the block in a E350. Mine is an 84 but anything from 83-88 and 90-94 should work.
Thanks!
Mike
EDIT: Couldn't afford the Ford $450-500 but Number Dummy pointed me to a place 'Vintage Parts Inc' in Wisconsin that had the part for 156 bucks!
  #75
Old 09-07-2015, 12:00 AM
kbautoserv kbautoserv is offline
KB AUTO SERVICES
kbautoserv is starting off with a positive reputation.
Wanted parts for my 1994 7.3 IDI N/A
New member, first post.
Looking to do a conversion and/or swap to turbo or drop a DI turbo in it, depending on how hard/do-able the conversion is vs. time and cost of a powerstroke engine
But parts I need for now:
-Instrument Cluster for manual trans, with tach, diesel.
-Steering column with ignition switch and keys, tilt preffered but not a requirement
In the middle of sanding/painting and re-wiring dash switches/ tow truck switch panels, starting my own tow truck company with this truck will post pics soon
Want to buy an original AM radio for 66 F350 Christopher Layton 1961 - 1966 F-100 & Larger F-Series Trucks 4 11-22-2015 02:11 PM
Want a diesel rc.chris 1999 to 2016 Super Duty 37 08-22-2015 11:52 PM
wanted 75 ranger key switch sawmaned WTB - Parts & other 1 08-01-2015 04:44 AM
What do you want to see on the 2016 truck? BigF350 2017 Super Duty 191 05-26-2015 04:29 AM
just wanted to say hi patsf150guy New Member Introductions 1 03-01-2015 12:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
