The parts wanted thread. - Page 2 - Ford Truck Enthusiasts Forums
Old 02-18-2015, 02:06 PM
Tinkerhell Tinkerhell is offline
Tinkerhell is starting off with a positive reputation.
Wanted: a complete steering column for my '89 f250. It needs to be an automatic (c6) & It came with a 'tilt' column- but a straight one would do.
Old 02-19-2015, 09:57 PM
tecgod13 tecgod13 is offline
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
Quote:
Where are you located?
I have a steering column that should work in Western Massachusetts. PM me for more details if you're interested.
Old 02-19-2015, 10:03 PM
Gold tramp Gold tramp is offline
Gold tramp is starting off with a positive reputation.
1983 6.9 diesel oil cooler
wanted complete oil cooler can use just the aluminum ends.
Thanks
Gt............
Old 03-14-2015, 04:41 AM
Romel77's Avatar
Romel77 Romel77 is offline
Romel77 is gaining momentum as a positive member of FTE.
Wanted instrument cluster with tach for F250 diesel 1986, the cluster without tach has different foil wiring, so no just add on. And by coinsidence tan bench seat, just the original cover in good condition. The truck is located in Arizona by my friend Thanks
Jan
Old 03-20-2015, 04:11 PM
juice0341 juice0341 is offline
juice0341 is starting off with a positive reputation.
looking for 94 7.3 idi turbo engine
Old 03-20-2015, 10:29 PM
FordTruckGuy96 FordTruckGuy96 is offline
FordTruckGuy96 is starting off with a positive reputation.
Looking for 6.9/7.3 idi, turboed or non, complete engine and trans setup, doesnt need to be running, near Detroit Michigan.
Old 03-29-2015, 11:10 PM
rangernut09011980's Avatar
rangernut09011980 rangernut09011980 is offline
rangernut09011980 is starting off with a positive reputation.
Need a complete steering column with wheel for a 1988 Ford F250 4x4 with tilt, Cruise (in the wheel) and a manual transmission. I am located Indiana 46012
I am also looking for the steel fuel supply line that runs from the lift pump back to wherever it is it actually starts near the selector valve. I heard there was a few years of these trucks that had stainless lines so I would prefer those over the regular steel.
Old 03-30-2015, 08:19 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
as per www.car-part.com there are three tilt columns listed in indiana
<table height="73" width="504" border="1" cellpadding="4" cellspacing="0"><tbody><tr><td>1991
Steering Column
Ford Truck F150
</td><td>GRY,CD,5SP,W/KEY</td><td align="center">C</td><td>141149</td><td align="center">$200</td><td>Wise Auto Parts, Inc. USA-IN(Richmond) 765-962-0602 / 800-898-9473 </td></tr></tbody></table>
<table width="100%" border="1" cellpadding="4" cellspacing="0"><tbody><tr><td>1989
Steering Column
Ford Truck F150
</td><td>
</td><td>024169</td><td align="center">$185</td><td>Cars and Parts USA-IN(Columbus) E-mail 1-800-225-9025</td></tr></tbody></table>
the other one is listed as parts only
as for the fuel line, i would just make a new one out of the copper/nickle alloy line.
Old 03-30-2015, 11:05 AM
charlie555 charlie555 is offline
charlie555 is starting off with a positive reputation.
radiator core support 1985 f250 with size opening 25-5/8 x 31-1/8
Old 04-04-2015, 12:26 AM
jmuenchow's Avatar
jmuenchow jmuenchow is offline
jmuenchow is starting off with a positive reputation.
TPS bracket mount that the two adjusting screws mount to the ip. If you have one please let me know I need one ASAP!! Thanks!!!!!
Old 04-04-2015, 02:41 AM
Ford F834's Avatar
Ford F834 Ford F834 is offline
Ford F834 has a very good reputation on FTE.Ford F834 has a very good reputation on FTE.Ford F834 has a very good reputation on FTE.
Quote:
Are you needing the linkages with the low idle and max throttle adjustments, or the throttle position sensor bracket? Do you have a picture of it or can you point it out in this diagram? I have some auto trans specific parts that came off of Romel77's truck when we did the ZF-5 swap, but if you need the actual throttle linkages on the passenger side of the IP we obviously didn't remove that stuff.
Old 04-04-2015, 11:11 AM
jmuenchow's Avatar
Quote:
No not the throttle linkages the physical bracket that the TPS itself mounts to (bracket that you then screw onto the pump. Will send a picture
  #28
Old 04-04-2015, 11:13 AM
jmuenchow's Avatar
this bracket that the tps is sitting on.
  #29
Old 04-04-2015, 03:16 PM
jmuenchow's Avatar
I was able to make it out to the junkyard today and found a pump. Went ahead and took it just for a core and I have the bracket
  #30
Old 04-14-2015, 09:07 PM
1993idi 1993idi is offline
1993idi is starting off with a positive reputation.
7.3l IDI throttle cable
I'm looking for a throttle cable for my 7.3l IDI. Ford wanted 136$ 😳
New from NY Ripemdry New Member Introductions 2 01-25-2016 12:00 PM
WTB tailgate cap Mad Mel C WTB - Parts & other 0 01-08-2016 09:48 PM
Fog Light's?? DocsExcursion Excursion - King of SUVs 21 10-31-2015 05:25 AM
wanted 75 ranger key switch sawmaned WTB - Parts & other 1 08-01-2015 03:44 AM
What do you want to see on the 2016 truck? BigF350 2017 Super Duty 191 05-26-2015 03:29 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
