The parts wanted thread. - Page 13 - Ford Truck Enthusiasts Forums
  #181
Old 11-24-2016, 10:53 AM
Fordfreak22 Fordfreak22 is offline
Fordfreak22 is starting off with a positive reputation.
Looking for a turbo for my 7.3 idi every were I'v looked only shows for powerstroke
  #182
Old 11-24-2016, 11:15 AM
Macrobb's Avatar
Macrobb Macrobb is offline
Macrobb is gaining momentum as a positive member of FTE.
Quote:
(Note - you may already know this, but...)
That's because, generally speaking, it's an aftermarket component.
93-94 did have a stock turbo on the IDI as an OPTION, but it's rare.
Because of this, you don't just need a turbo, you need a turbo + exhaust piping + intake piping and adapters.
Generally speaking, there are three 'main' kits out there:
1. Banks Sidewinder - comes in "V1" non-wastegated and "V2" wastegated models. Castings are different between the two kits; the wastegated model is a lot easier to install with the engine in the vehicle.
2. Hypermax - Has their own kit; you may see them around. I don't know much about these.
3. ATS - They both made their own kit, and a modified version of their kit was used as Ford stock(the main difference with the Ford version being a squished up-pipe that robs performance).
If you are buying new, R&D(idiperformance.com) has their own kit that's /much/ better, but just as expensive as all the others.
If you are buying used, you kinda have to look around and see what you want.
If you are a fabricator who can make exhaust piping(up and down pipe), you can basically get whatever turbo you want for the power level you want to make. The standard kits(1,2, and 3) are all designed for stock motors and won't give you more than about 12 PSI at best. Good for a stock engine, not so much once you get headstuds in the picture.
Anyway, hope that helps a little.
  #183
Old 11-29-2016, 10:53 AM
Moore558's Avatar
Moore558 Moore558 is offline
Moore558 is starting off with a positive reputation.
Looking for the brass tee fitting shown below that is used in the return lines of 92-94 IDI engines.
  #184
Old 01-25-2017, 09:19 AM
Ol'Moose86 Ol'Moose86 is offline
Ol'Moose86 is starting off with a positive reputation.
Im looking for a 83-86 diesel tachometer. it doesnt have to work.
also looking for the wiring harness for the digital clock option in the 80-86.
  #185
Old 01-31-2017, 11:58 PM
jmuenchow's Avatar
jmuenchow jmuenchow is offline
jmuenchow is starting off with a positive reputation.
tach sensor for my 91 7.3 idi. pm for price if you got one thanks!!
  #186
Old 02-17-2017, 08:28 PM
Herb Brooks Herb Brooks is offline
Herb Brooks is starting off with a positive reputation.
I'm gonna pull the 6.9 tomorrow I think it will work. Has some cracked insulation on the leads but works well.
  #187
Old 02-26-2017, 03:48 PM
eagleye eagleye is offline
eagleye is starting off with a positive reputation.
88 VAN Steering wheel cruise control button horn panel
I'm looking for the cruise control button assembly for the steering wheel.
Funny thing, I got the van and the steering wheel doesn't have the cruise control. The horn doesn't work. Then I notice I've got everything for the cruise control but the buttons. Checked the diagram and the current horn button and found out it must have been swapped out at some point.
I verified the horn works per the ford factory cruise diagram. Funny thing is the way the horn button is now wired, the only function it would have is turn on the cruise. Somebody pulled a fast one on the PO.
I also found out the buttons I am looking for from the steering wheel should work with any Ford Bronco, pickup, van that had the cruise and horn buttons combined from about 1980 through 1991.
If you have an extra, please contact me.
  #188
Old 02-27-2017, 06:24 PM
thanks, i think i found one that may work.
  #189
Old 02-28-2017, 07:23 PM
pba369's Avatar
pba369 pba369 is offline
pba369 is starting off with a positive reputation.
Looking for a fuse panel 89 f250 idi
  #190
Old 03-01-2017, 03:25 AM
DarkOverCast DarkOverCast is offline
DarkOverCast is starting off with a positive reputation.
Quote:
Power windows/locks? Trans type may be a defining factor as well. At least for the harness. Someone may have an interior harness and fuse box combo to save you the splicing!
  #191
Old 03-01-2017, 08:29 AM
pba369's Avatar
Quote:
It's an XLT package. Has power window/locks and I suppose a C6.
  #192
Old Today, 07:28 PM
chillman88 chillman88 is online now
chillman88 is starting off with a positive reputation.
Need a dark blue seatbelt for my 91 crew cab driver side rear seat. Anyone know if a front belt will work in the rear?
New from NY Ripemdry New Member Introductions 2 01-25-2016 12:00 PM
WTB tailgate cap Mad Mel C WTB - Parts & other 0 01-08-2016 09:48 PM
Fog Light's?? DocsExcursion Excursion - King of SUVs 21 10-31-2015 05:25 AM
wanted 75 ranger key switch sawmaned WTB - Parts & other 1 08-01-2015 03:44 AM
What do you want to see on the 2016 truck? BigF350 2017 Super Duty 191 05-26-2015 03:29 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
