Wouldn't either one work like a radiator? Where the air hitting it is usually fresh.
If the air around the pan was fresh there would be some cooling from the pan. But the air around the pan is HOT, so it can't cool the transmission. It doesn't matter if you have cooling tubes or cooling fins, when the air hitting them is hot it won't cool the trans.
Originally Posted by chaser1602
Has anyone done any research why you have to change the pan? Why not just use the 08 filter? Cant some heat and a hammer fix the situation?
As long as you modify the pan correctly so that the flow into the filter is right, that will work. If you do it wrong the trans will starve for fluid and you'll need a new transmission. Just make sure to do this right, and test and measure the flow inside the pan, just like was done designing the OEM pan.
You would have to add material to the pan -- it ends up taking an additional qt of oil, so in my opinion no, you can't just pound the pan into a bigger shape...
Nuthin a cupla beers wouldn't take care of [/QUOTE]
heh heh heh -- ok, you really want to try it? (after a few beers of course) -- I have my old pan you can have for free, that way you don't even have to take yours off, just pay whatever shipping is and I'll send'er on over.
Before and After picts will be required -- everyone on FTE with a pre-'08 Torqshift will want to see it
And has anyone considered that the air around the trans pan is HOT? You can't cool the trans with hot air, cooling fins tubes or not.
Yeah, the air around the pan would certainly be "warm" since most of that air comes from the (hot) radiator discharge and engine compartment.
Trying to make a heat exchanger work in that environment would be akin to placing a conventional trans cooler behind the radiator. it would cool the fluid if the air was cooler than the fluid......... since the that air is not very cool, it couldn't do much....
I would rather just use a conventional heat exchanger and either put it front of the radiator or some place else where it can get a good supply of ambient air...........
That "08" filter appears quite a bit larger than the original one
(the surface area of "tight" filter media would have to be more to achieve an adequate flow) .
I would have to guess that the pan is "just-right" to fit the filter. It doesn't take much increase in pan dimensions to cause a significant volume increase...
"Heat and hammer"? for a roughly $60 pan purchase? I wouldn't waste my time trying to "modify" a pan that costs less than an oil change.............. (or less than a tank of fuel!!)
