2000 f350 brake issur
Old 01-25-2015, 12:43 PM
Tallee's Avatar
Tallee
Tallee is offline
I am having a major issue with my truck. I replaced all of my brakes about 8 months ago. Replaced everything. Rotors, calipers, pads etc. About 3 weeks ago I pushed on the brakes and they locked up and I heard a loud pop and then grinding. I pulled my wheel and my brake on the right rear had broke the 2 mounting bolts and fell off. So I put the brake back on thinking I hadn't tightehed the bolts. Drove about 7 miles and around the 10th time I stepped on my brakes it did the same thing. So I replacec the brakes again. Calipers caliper mount and pads. I have been driving it 2 weeks and all of a sudden same thing happened. I push on the brakes the right rear locked up and snapped the bolts again. So now I replaced wverything rotor calipers etc. Greased everything up and no problems for a day. Any ideas? Do I need to replace the brake mount and where do I get that? Any help will be great.
Travis
Old 01-26-2015, 06:35 PM
pdqford's Avatar
pdqford
pdqford is offline
Are you using the correct grade bolts?
mrcrownline
02-15-2013 08:07 PM
Mike in Ohio
1997-2006 Expedition & Navigator
09-05-2011 09:46 PM
gtripledip
12-03-2006 09:32 AM
Ryker
1997 - 2003 F150
09-30-2006 06:41 AM
plugugly
05-13-2003 02:39 PM
Quick Reply: 2000 f350 brake issur
