Quiz: what model of 2014 Ford F-150 do I have?
If you asked me what "model" of Ford F-150 I have and I said "I have a 2014 F-150 Heavy Duty", would you think:
a) I know nothing about the Ford F-150 truck models available in 2014
b) I have a Ford F-250 Super Duty
c) I have a Silverado 2500 Heavy Duty, not a Ford
d) I have a serious drug and/or drinking problem
e) your answer here: _______________________
(I know the correct answer here. But I just want to know what other normal, intelligent truck guys and gals think. )
The correct answer is "there is no such model as an F-150 Heavy Duty".
You can buy an F-150 XL, an F-150 XLT, an F-150 Lariat, an F-150 King Ranch or an F-150 Lariat. But I defy you to find a model of truck called an "F-150 Heavy Duty" on Ford's web site, in a dealer show room, on a used car lot or anywhere else you can think of.
An F-150 XLT with a Heavy Duty Payload Package is an F-150 XLT model. If you want to know what optional equipment your XLT model has, then that's another question entirely.
Yet Tire Rack would tell you differently.
What is an "F-150 2wd Heavy Duty"? What is an F-150 4wd Heavy Duty". There is no such model of F-150 truck.
Just for the record, I have a 2014 Ford F-150 4WD XLT with extended cab, 8 ft. box, Trailer Towing package, Heavy Duty package. Of course I know this because I did a special order for the truck and requested these options in the special order.
The quiz above was just that - a survey to solicit your thoughts on what some confused person - such as the Tire Rack web site designer - might mean by "F-150 Heavy Duty".
By the way, that data doesn't come from Tire Rack... they purchase third-party database content to drive those menus. The Heavy Payload Package vehicles are sufficiently different (tires, wheels, axles, etc.) that they get their own entry.
Honestly, you have nothing better to do than argue this? You know what they say about arguing on the Internet...
The point is if you want to know what options a truck has, then that's what you should be asking. Don't confuse "model" with "options".
QwkTrp got it right when he said "No different than me saying, I have a Tow Max. No I don't, I have an XLT with Tow Max." Absolutely correct.
If you were having open heart surgery and the surgeon asked for a forceps when he/she really meant a scalpel, don't you think that would be an important distinction?
Use the right terms for things and you generally can't go wrong. Unless you're on an internet forum, that is.
to take your argument one step further, they should also remove 2wd and 4wd.
of course, to do so would add another step into figuring out what tires your truck needs.
furthermore, XL, XLT, Lariat, Platinum, and Limited also have no place in the "model" category, as they are simply option packages on the F150 model, despite the fact that they have a defining difference on tire options.
if you feel that semantics is your forte, then enlighten the group on the best way to make the distinction, particularly in this case, between truck with the max payload and trucks without?
FWIW, your own poll is not supporting your cause. Most on here seem to "get it" rather than getting caught up in the semantics of ford's nomenclature, vs tire rack's (or the 3rd party, as noted above).
