GADJETFREAK
When you press the "O/D Off" button does the transmission seem to not be allowing overdrive? If not, then there's a pretty good chance the issue is with the wiring for the O/D Off switch. That was somewhat common on older Explorers. I'm not sure if the O/D Off switch is still on the shift lever on your 2007 or not.
A professional scan tool may have the ability to turn on the O/D Off light from the tool to confirm whether or not the bulb is working properly. It would also allow you to confirm whether or not the switch is working.
-Rod
-Rod
wharthog
11-09-2017 09:18 AM
P Suckow
08-23-2017 06:45 AM
brettster55
1999 to 2016 Super Duty
08-11-2007 02:32 PM
