49 F1 Instrument Cluster Info
Working on the wiring for this and there is a 1" square ceramic piece that I believe is the voltage reducer with wires from the ignition switch through the device and then to the lower left of the cluster. Currently this was laying on the inner ledge of the back of the dash and unsecured so it was obviously shorting out. Looks like it has a 7/16" threaded post with lock nut to attach to something so its secure. Any ideas on where this goes on a stock truck? I can secure it but prefer to put it where it belongs.
Dick I think we need more info. Sounds like its 12Vt so somebody put the
ceramic reducer there. There is much said about voltage reducers. However
back around 1960 my father put a 57 Ford gen & regulator 12vt neg grd,. in our F6 reversed the feed thru the ampmeter. no regulator. Till this day gauges
always worked on straight 12volts. So if vt. regulator is manditory, don't
you think my gauges would have fried 55 years ago????? Same thing with
6 volt heater many owners run 12 vts to a 6vt heater including me.
Or maybe I'm just lucky..
srfordf100
03-20-2015 02:16 PM
JBronco
1978 - 1996 Big Bronco
10-17-2004 10:21 PM
