Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Old 01-24-2015, 08:20 PM
Bear999 Bear999 is offline
Bear999 is starting off with a positive reputation.
1986 f-150 no start
86 F-150 5.0 EFI. Started one day ran fine then just shut off. Would not restart. Fuel pressure key on engine off (KOEO) 10psi first prime, 20+ second prime, 40 on third prime. 40psi while cranking. All fuel pumps running. Has spark. Replaced coil, ICM, plugs, wires, cap and rotor, TPS, and pick-up coil. Timing is correct. Firing order correct. Only codes were ACT and EGR. Stuck please help.
Old 01-25-2015, 08:25 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
After a cranking session pull one of the plugs. See if it's wet with fuel or dry.
__________________
Dave F
1989 F250 XLT Diesel
Old 01-25-2015, 09:28 AM
Hi Dave.
Thanks for the reply Dave. I will pull the new plugs and check. When I changed the old ones they were damp, with #1 & #4 being the worst. Also I am getting voltage at ICM harness, SPOUT connecter, and misc. sensors. Used NOID light on injector and OK. Thinking at first fuel issue tried starting fluid, not a bark. The only time we have had any sign of improvement was after tune-up it briefly, and I mean briefly, acted like it wanted to start. But then just dead crank over and over. I believe timing is correct. At o TDC #1 intake and exhaust valves up, rotor pointing to left of #1 distributor cap pin.
Thanks.
Old 01-25-2015, 07:40 PM
Hey Dave,
Pulled #5 its wet.
Old 01-26-2015, 12:45 PM
Franklin2's Avatar
If you are positive you have spark, with a good battery hold the accelerator pedal to the floor and crank it. See if it tries to start or does start. Holding it to the floor while cranking will turn the fuel off to the injectors. It puts the computer in a "clear flooded engine" mode. If you have good spark, it seems you are getting too much fuel for some reason.
__________________
Dave F
Old 01-26-2015, 12:52 PM
I thought of the same thing as well. Did not work. Just dead crank. Tested spark at coil wire to distributor and at plugs with calibrated spark tester. Blue spark. But that was before tune up. Will check again. Thanks.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
