Looking for advice/help on engine removal/install on '90 5.7L
Old 01-24-2015, 03:08 PM
playsintraffic's Avatar
playsintraffic
playsintraffic is offline
This is the largest wrenching project I've ever tackled and I'm just looking for any tips/tricks or anything that might help. I've done some searching on google and haven't found a lot. If a DIY guide exists anywhere that would be awesome.
Truck is a 1990 f-350 with a 5.7L.
correction, 5.8L
Old 01-24-2015, 03:25 PM
Conanski's Avatar
Conanski
Conanski is offline
Is the engine going back in the same as what is coming out? Meaning same year and everything? Or are you doing a different combo?
Old 01-24-2015, 03:28 PM
emspjay's Avatar
emspjay
emspjay is offline
Take lots of picture for reference before you start and during the removal. Label everything very well, I use 2in wide blue masking tape and a sharpie pen. Get a bunch of lunch and freezer bags to place bolts and small parts in and label them with the sharpie pen.
Old 01-24-2015, 04:39 PM
playsintraffic
another 5.7L is going in. good tips on keeping track of everything, thank you.
Old 01-24-2015, 05:14 PM
Nothing Special's Avatar
Nothing Special
Nothing Special is offline
5.7? Ford's larger small block is a 5.8 liter (351 cubic inches).
Old 01-24-2015, 05:51 PM
playsintraffic
right 5.8L shows you how familiar with ford i am
Old 01-24-2015, 07:20 PM
Conanski's Avatar
Conanski
Conanski is offline
So another 5.8 going back in.. dame year or a different one?
The main thing is that you cannot use any wiring that comes with the donor motor, so remove the upper intakes on both motors and disconnect all of it.
Electrical connectors are mostly unique to the device they connect to so it's hard to get things mixed up even if you don't label them.
The motor will come out without removing the hood and rad but some guys pull those parts anyway, and it's easier to leave the trans in the truck if you have a 4x4.
Old 01-24-2015, 07:27 PM
playsintraffic
I'll have to check but I believe it is the same year. Even if it is I have to swap all the electricals?
Also it is a dually flatbed, I don't think it's 4x4, does that change anything about what I should do with the tranny?
Do you know if I can pull the fan clutch w/o a special tool? Are there any other specialized tools I'll need?
Old 01-26-2015, 11:27 AM
playsintraffic
to the top.
i read somewhere that i may need an incredibly long extension with multiple elbow joints to access the engine to transmission bolts. does anyone know if thats the case?
Old 01-26-2015, 03:32 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,151 Likes on 910 Posts
Originally Posted by playsintraffic
to the top.
If you are removing the bellhousing bolts from underneath then yes, an assortment of extensions and u-joints come in very handy. I would not say you need multiple elbows, just the one on the end near the socket.
If you are coming in from the top, not very easy IMHO, then no.
herbey123
07-30-2018 08:35 PM
Audacious
2011 to 2019 Explorer
05-14-2018 06:23 AM
Nick_S
General Automotive Discussion
01-30-2011 11:28 AM
Georgia Dentside
15
01-07-2011 10:09 AM
fordf350crazy
07-10-2009 05:52 PM
Quick Reply: Looking for advice/help on engine removal/install on '90 5.7L
