Re-Programming the Remote Keyless Entry - Ford Truck Enthusiasts Forums
Old 03-30-2002, 11:19 PM
riffraff riffraff is offline
riffraff is starting off with a positive reputation.
I have the procedure to re-program (add a new remote to) the remote keyless entry on 1994 (and similar) F-Series. The procedure first involves jumping some pins at the "programming connector" so said to be located at the base of the steering column.
Does anyone know which (of the many) connectors this refers to?
Old 03-31-2002, 10:40 AM
Mattman1 Mattman1 is offline
Mattman1 is starting off with a positive reputation.
Post Re-Programming the Remote Keyless Entry
O.K. It is a gray two wire connector. There is nothing plugged in to it. It is located right behind the little cubby hole thingy to the right lower area of the column. When you jump it the locks should cycle. This confirms that you are in program mode. Then you need all remotes you will be using with this truck. One at a time lock or unlock the doors. Make sure you program all remotes at the same time, I blieve the system is set up for up to 4 remotes.
Old 03-31-2002, 12:25 PM
got it working, thanks!
Old 03-31-2002, 01:52 PM
CantDrive55 CantDrive55 is offline
CantDrive55 is starting off with a positive reputation.
Old 03-13-2006, 11:56 PM
JimTZ JimTZ is offline
JimTZ is starting off with a positive reputation.
I can't see any connector behind the little cubby hole thingy on my 94 F150. It also has the factory alarm --- does that make a difference?
Jim
Old 02-22-2010, 07:22 PM
rken801 rken801 is offline
rken801 is starting off with a positive reputation.
1994 F-150 XLT reprogramming keyless entry
I recently installed a new receiver module as my old one burnt up. I found an open 2 prong connector under the steering column that was taped into the wire cluster. I bent a paperclip into a U with small half-loops at the ends. I put it into the connector touching the prongs and then turned the key to ACC position. My truck immediately clicked the locks and then I hit any button on my first remote. My truck folowed with another clicking of the locks and then I repeated with the other remote and it clicked the locks ,also. Then I turned the key off and there was one last clicking of the door locks and then I removed my paperclip. Now everything works perfectly with both of my remotes!
Old 11-14-2010, 02:51 PM
BULLYXVIII BULLYXVIII is offline
BULLYXVIII is starting off with a positive reputation.
I located the grey connector & the 2 pins.
Then I shorted the 2 pins together while the key was in the ignition on acc. Nothing happened. Anyone have knowledge of what this means or what the problem can be?
Old 05-18-2011, 11:56 AM
PKTDERK PKTDERK is offline
PKTDERK is starting off with a positive reputation.
My 1994 F-150 did the same thing. I wonder if electric locks were standard, but the keyless remote receiver was not. Maybe our trucks don't have the receiver installed. When I short out the grey programming connector, with the key in the "ON/ACC" position, the locks do not cycle to indicate I am in programming mode. It makes me wonder if there is even a receiver to program. Does anyone know where the receiver is located?
Old 05-18-2011, 12:23 PM
thechief66's Avatar
thechief66 thechief66 is offline
thechief66 is gaining momentum as a positive member of FTE.thechief66 is gaining momentum as a positive member of FTE.
Very few trucks of our era had remote keyless entry. Being equipped with power locks doesn't mean you have RKE.
Old 05-24-2012, 03:38 PM
CHRGD's Avatar
CHRGD CHRGD is offline
CHRGD is starting off with a positive reputation.
I just did my 1994 F150, my old remote went bad. I followed the above explanation, and my locks did not work either. Upon looking around I found another connector taped to the harness for the security system. Just a bit to the right of the column. The one taped to the wires for the column is not the one you need. They look identical, but use the one to the far right, grey connector, 2 wires, with nothing plugged into it. Thanks guys for this process. Saved me a bunch of headaches!
1994 F150 keyless remote questions 77_150 1987 - 1996 F150 & Larger F-Series Trucks 1 03-16-2015 06:05 PM
Keyless Remote for 93 Explorer tdoyle Electrical Systems/Wiring 8 05-23-2014 04:10 PM
keyless entry Gary Tice Electrical Systems/Wiring 3 11-22-2013 03:22 PM
Keyless Entry Programming Help DeathRowe 1987 - 1996 F150 & Larger F-Series Trucks 0 10-23-2013 08:30 PM
94 Ford Explorer - Remote Keyless Entry system yvonnemcav Explorer, Sport Trac, Mountaineer & Aviator 2 02-27-2002 09:43 AM
Tags
1994, 2000, connector, door, econoline, entry, f150, ford, instructions, keyless, program, programing, programming, remote, truck, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
